1972 Pinch Weld Molding Came LooseW
Old Dec 6, 2014 | 07:00 AM
brown7373's Avatar
The pinch weld molding came loose last night. We were lining up for a Christmas parade and it was dark. I can't see any obvious way it attached, but it was in the dark. My Bonneville has tabs that get screws to attach it underneath, but I didn't see any tabs.
Does the Cutlass attach the same way?
Old Dec 6, 2014 | 07:11 AM
mrolds69's Avatar
!969-72 Cutlass attach with screws. I think 1968 used clips + screws. I'm not sure about earlier. Sometimes people use clips on the later cars. Some repro moldings the holes don't line up, so people don't screw them on right.
Old Dec 6, 2014 | 10:04 AM
brown7373's Avatar
I didn't get a good look last night in the dark, but I didn't see any tabs and screws
Old Dec 6, 2014 | 11:00 AM
mrolds69's Avatar
You need to put the top half-way down. Then you need an inspection mirror or small handheld mirror to look underneath and see what's there.
Old Dec 16, 2014 | 09:24 AM
brown7373's Avatar
My original molding had ben riveted. I used a bur bit in a Dremel tool and got them removed fairly easily, but the holes on the new pinchweld from OPGI were no where close to lining up. I will have to drill new holes.
Do most people use screws or rivet them? I had screws on my 70 Bonneville, and years of water caused the phillips heads to rust and corrode and impossible to remove with a screw driver.
Old Dec 16, 2014 | 03:24 PM
mrolds69's Avatar
Most people use screws. Right...aftermarket moldings don't line up with the holes...not even close. There is a good article on the web for a GTO with pics that shows how to measure for the holes and install the mldgs. I would use screws, your car will most likely never see the kind of weather it once did. Other options are SS screws, torx or hex head screws which would be easier to remove if needed.
Old Dec 17, 2014 | 05:46 AM
brown7373's Avatar
Thanks. I'll search for the GTO article. I can se where being a little off with drilling the holes could result in a loose or misaligned pinchweld.
Old Dec 17, 2014 | 05:56 AM
mrolds69's Avatar
Here is the article http://www.carsandparts.com/Articles...-To/in-a-pinch These repro moldings are another example of a poor copy. They are pretty good looking, reasonably priced, they are very similar to originals and attach in a similar way. They are cheaper to buy than sending your own out to be straightened + polished. Why they couldn't get the holes in the same places, I just can't understand! And...it's a huge difference in distance. Ames sells the correct screws, or clips and screws if you go that route.
BeenThere
Sep 27, 2014 06:54 AM
blaque3001
Sep 9, 2014 11:47 PM
rojoe
Jul 31, 2012 10:46 AM
KZ442
Jan 10, 2011 06:07 AM
luddie
Jul 27, 2008 09:43 AM
