bucket seat bracket questions
Old Nov 18, 2012 | 03:16 PM
MBrown's Avatar
Hi, have a 1971 cutlass with bench seat, bought bucket seat brackets. no instructions, of course, do you just set the seats and spot weld the brackets in place?? there are bolt holes for the outer tracks and i assume the conversion brackets are for the inner tracks, is that correct??
thanks in advance,
Mark
Old Dec 18, 2012 | 04:44 PM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
I'm sure the conversion brackets are for the inner tracks. I would install the inner brackets to the seats and bolt the outer tracks to the floor, line up the seat then spot weld the inner bracket. Maybe the body service manual or assembly manual would help.
Old Dec 18, 2012 | 04:53 PM
ziff396's Avatar
[QUOTE=67Olds442X2;487268]I'm sure the conversion brackets are for the inner tracks. I would install the inner brackets to the seats and bolt the outer tracks to the floor, line up the seat then spot weld the inner bracket.
That is how I did mine. Worked out great. Like said, make sure you line up the seats first before welding.
Old Dec 18, 2012 | 06:01 PM
MBrown's Avatar
Thanks Guys!! Thats the way I ended up doing it.
Old Dec 19, 2012 | 09:14 AM
72CS's Avatar
I'm also converting my car to buckets but I don't have a set of original seats......yet. Could someone tell me which of the bench seat holes is used for the bucket seats, the forward or rear bolt on each side?
And what is the distance between the outer bolts (close to the rocker) and the inner bolts (close to the trans hump). With these measurements I can make a template to get my brackets in the proper position in the car.
Old Dec 19, 2012 | 09:27 AM
RAMBOW's Avatar
Ben
Lots of good info on the conversion on this page:
http://www.chevelles.com/forums/showthread.php?t=192782
Old Dec 20, 2012 | 03:38 AM
cdrod's Avatar
Rodney
bucket seat alingment
Hey 72CS:
I'm in the middle of a full resto of a '72 convertible; I can take some measurements for you. I need to do this anyway as I plan to replace the floor pans.
Old Dec 20, 2012 | 01:19 PM
72CS's Avatar
I went through the entire thread on the Chevelle site. Some of the pictures wouldn't come up but I think I got enough to go ahead. I'm going to make a square out of cardboard and put 4 holes where the bolts should go. Then I'll use the rear bench seat mounting holes as the reference point. I should be able to get the brackets in their proper place. Thanks for your help everyone.
old442x3
Oct 23, 2014 05:58 PM
SuperSquid
Nov 21, 2013 02:42 PM
sx455raidercelticfan
Dec 26, 2010 04:13 PM
Dec 21, 2010 08:59 PM
dc2x4drvr
Oct 19, 2009 04:20 PM
