Help please...When will I get all the bugs out...
Maybe someone can answer my question again...really thought i would have my Olds ready to drive today, but another problem arises..Seems my fan blades want to hit my fan shroud.. Can any one tell me what the problem may be.. Do I have the wrong shroud or maybe the wrong fan blade..Motor mounts were replaced...Has a 5 blade clutch fan on it..hits on the bottom of the fan shroud..really bad when driving and braking.. Any suggestions?? thanks...Snookys71Olds
Well, you got some of them:
- Wrong shroud
- Wrong fan
- Wrong clutch / spacer (if it came with one setup, and you've mixed and matched parts of the other)
- Bad clutch (wobbly)
- Bad water pump (wobbly)
- Something messed up with the motor mounts (mixed and matched?)
- Something messed up with the trans mount (too high)
- Fan shroud bottom tabs not pushed fully into their clips in the bottom radiator mount
- Wrong shroud
- Wrong fan
Not much to do but start ruling things out.
BIGJERR
September 5th, 2012 04:33 PM
