timing chain play
Old Feb 4, 2012 | 04:29 PM
jdiggitydogg's Avatar
timing chain play
I am restoring engine compartment 0f my 66 cutlass putting all new gaskets in the motor has 102,000 miles timing chain seems loose best to replace now while out? how much play can there be in the chain?
Old Feb 4, 2012 | 06:12 PM
Olds timing chains should be replaces around 100,000 miles whether they need it or not.
I blew an engine (bent numerous valves in both heads, was a kid with no money and no place to fix it) at 106,000 miles, at idle, once.
Old Feb 4, 2012 | 10:57 PM
ah64pilot's Avatar
Don't the factory timing gears use hard plastic teeth? It's been forever since I pulled apart a stock engine but I think I remember them being plastic. I'd say change it now while it's apart...they're not very expensive.
Old Feb 4, 2012 | 11:08 PM
don71's Avatar
same but different
Its perfect time to swap it out , replace it now and don't look back.
Old Feb 5, 2012 | 06:24 AM
Highwayman's Avatar
I'm not sure what year GM started using the fiber gears, but I think it was in the late sixties. Those should come out regardless of mileage before you end up digging pieces out of the oil pump pickup.
Old Feb 5, 2012 | 08:57 AM
citcapp's Avatar
Replace both chain and gear with a good quality set. Cheep insurance http://www.cloyes.com/
Old Feb 5, 2012 | 09:11 AM
Rickman48's Avatar
And water pump while off!!
Old Feb 5, 2012 | 10:47 AM
timing chain
thanks alot gonna replace timing chain and water pump never done chain and gear before any tips thanks for your help
Old Feb 5, 2012 | 10:57 AM
Personally, I wouldn't go more than 80,000 miles on the stock plastic cam gear. An all-metal timing set will go much further. The factory single-roller chain in my crewcab dually looked brand new at 150K miles. I replaced it anyway (hey, with the front of the motor that far apart...).
Old Feb 5, 2012 | 11:16 AM
Rickman48's Avatar
Get a gear puller and a balancer puller before you start, loosen the first 8 bolts on the oil pan before removing the timimg chain cover, use some brake clean to spray oiley surfaces, and get some silicone sealer to caulk all the 'leak spots'!
Old Feb 5, 2012 | 11:23 AM
ah64pilot's Avatar
In addition to what Rick said, make sure your timing marks are lined up on the cam gear and the crank gear before you pull the old one off. It'll be a lot easier to put the new one on in this position.
http
Apr 26, 2013 09:58 AM
442scotty
May 13, 2009 05:42 PM
dccutlass
Sep 17, 2007 03:08 PM
Mr. King
Mar 25, 2007 12:33 PM
olds87
May 24, 2006 08:30 PM
