need more torque, But not a wanna be drag car
Old Jun 26, 2007 | 07:28 AM
old-mans-mobile's Avatar
I have recently purchased a 1988 oldsmoble cutlass ceira international series with a 2.5 four tech and has close to 200,000 miles on it. I am getting ready to maintinance on the car and I was wondering if there was a way I could gain a little more power on the bottom end without sacificing gas milage or endangering the motor nor ride quality and not going into the motor, this power is from idle to about 55 mph, after 55 the car takes off. I am also suspecting the transmission of needing a overhaul. any advice would be greatly help.
P.S this lack of power is pressing the petal about 1/2 way or less.
Old Jun 26, 2007 | 08:09 AM
Oldsguy's Avatar
Past Administrator
I bet a basic tune-up would do wonders. Plug wires, plugs, etc. Maybe have someone run a check to see if the engine is throwing any codes. If you have a bad oxygen sensor for example, it will cause the engine to run poorly and the computer should throw a code that would indicate that.
Old Jul 1, 2007 | 06:47 PM
marcar1993's Avatar
Are the 1988's rwd. If so, try a more agressive, higher, rearend ratio. You will lose alittle gas milage, but the performance is worth it.
Old Jul 1, 2007 | 07:37 PM
88 coupe's Avatar
Junior Member
Originally Posted by old-mans-mobile
........ a way I could gain a little more power on the bottom end without sacrificing gas mileage or ........
A simple change to a lower final drive ratio can make a significant improvement in first gear acceleration from zero. In some cases, small ratio changes have been known to increase mileage instead of the expected decrease.
As I understand it, sprockets in the chain drive and/or the ring and pinion in the differential can be changed. Don't know anything about parts availability for your application, but it might be worth checking into.
Norm
Old Jul 2, 2007 | 09:13 AM
Norm
First, this car IS FWD. As Norm points out, final drive parts can be changed, but it is a big deal. Also, any change to a higher numerical final drive WILL hurt gas mileage.
The 2.5 engine is the old Pontiac Iron Duke. Hipo parts used to be available for this motor. Frankly, the least expensive way to upgrade this car is to swap the complete drivetrain from a V6 version.
Old Jul 8, 2007 | 07:25 PM
Redog's Avatar
IF you do swap the motor, go with the 2.3 HO motor. These motors where little 4 bannger rockets.
I think this was the motor that was in the last of the 442's in the early 90's
An it was an Oldsmobile, not a Honda Civic or a Mitsu, that was the first 4 cyl car to run in the 14's in the 1/4 mile
Old Jul 9, 2007 | 09:24 AM
The Quad 4 is NOT a bolt-in replacement for the Iron Duke. I don't think this motor was ever offered in the Ciera line, was it?
Old Jul 9, 2007 | 06:52 PM
zbuickman's Avatar
yes it was it came in black only with gold trim and tan interior. and was badged quad 4-4-2 oh nevermind that was a calais or was it??? its been along time since Ive seen one
Edit: IIRC this motor could also be had in the Achiva SCX
Old Jul 10, 2007 | 09:19 AM
It WAS the Calais, NOT the Ciera. Two different car lines. The Quad 442 (how I hate that name...) was available in colors other than black. I've seen several in red.
aribera94
Dec 11, 2014 11:46 AM
coltsneckbob
Dec 28, 2010 06:56 AM
Oldsmofjord
Jul 30, 2007 04:30 AM
t_visker
Dec 17, 2006 05:48 AM
Redog
Oct 7, 2006 02:00 AM
