Loose convert top
Old May 9th, 2018, 10:07 AM
Cutlass Fan's Avatar
Loose convert top
Not sure if this is the right place to ask this question.
The convertible top fabric has either stretched since installation or was not tightened sufficiently when installed. I do not know who did the installation. Is it possible to re tighten it and can I do it myself?
Cutlass Fan is offline
Old May 10th, 2018, 12:04 AM
69 Ragtop's Avatar
This could be caused by several things, depending on where the loose fabric is. Staples could have pulled loose, screws holding the rear retaining bar could have their holes stripped out, screws holding the frame together - or to the car - could have come loose, the sail panels could have come unglued, etc.
A picture or two would go a long way...
69 Ragtop is offline
Old May 10th, 2018, 04:12 PM
All the mechanical parts are tight. It just seems that the fabric should be tighter. When it rains water collects in puddles in two or three places on the top. Next time it rains I'll take some pics. Maybe this is normal? It's my first convertible.
Old May 11th, 2018, 12:18 PM
D. Yaros's Avatar
I have a convertible and have been thinking about your problem. My thought is that this is -NOT- a task I would be handling myself.
I would get a professional assessment of the situation and then think about the what/how to remedy.
D. Yaros is offline
Old May 11th, 2018, 12:34 PM
TomT's Avatar
Definitely should not be puddling.
TomT is offline
Old May 15th, 2018, 09:07 AM
Here is a picture after a shower
Old May 16th, 2018, 07:49 AM
TomT's Avatar
That shouldn't be happening. I replaced my top last June because the old one had a couple of tears but even the old one never did that. Not sure how to fix something like that without replacing it. Hopefully the frame is okay.
TomT is offline
Old May 16th, 2018, 07:54 AM
69 Ragtop's Avatar
I see the car's been sitting outside. Did it sit out in the winter where heavy Saskatchewan snow loads would stretch the material? If so, it's time for new fabric and a check of the frame. The fabric had stretched front-to back only you could unstaple the fabric at the header bar (front) and re-stretch it, but it appears to be stretched in both directions.
Old May 16th, 2018, 12:39 PM
The top has "tabs" that are glued under the side window seals, so those would also need to be detached in order to move the fabric forward.
Fun71 is offline
Old May 16th, 2018, 03:53 PM
The car was stored inside for the winter as it was the winter before. Prior to that don't know. The roof frame appears in like new condition but I can't tell if it's been flattened some. I guess I'll have to take it to an installer and see what they say. I was hoping it might be something I could fix myself.
kyleg
Ninety-Eight
June 11th, 2016 04:32 PM
vistacruiser1971
November 9th, 2013 01:19 PM
knighthawk
July 8th, 2011 08:02 AM
72 Olds Supreme
January 5th, 2011 08:44 PM
Old Whitey
November 25th, 2006 08:19 PM
Quick Reply: Loose convert top
