69 Cutlass Convertible
I can't wait to get started.
One question..so far.. both front doors get stuck on the front fenders and won't open all the way. Any suggestions on what to repair?
Thanks for the quick reply. I was thinking the same. I've removed the front bumper and trim, Would I just loosen the fenders and try and shift them to the front? I can't see that the fenders are bent to dented.
Loosen the core support at the frame, loosen top and bottom fender bolts, and loosen the bolts in both door frames. Shift everything forward to clear while watching your door to fender gaps.
You may have some stressed and/or bent parts.
Thanks for the advise! I'll try that today.
Hang on a second. The real problem is that the curvature of the front fenders just in front of the doors does not match that of the doors.
There are two bolts at the bottom of the fender, behind the wheel opening, that bolt upwards into clip nuts at the bottom of the cowl. These bolts force the bottom of the fender upwards and cause it to "spring" outward to match the door contour when properly aligned. Frequently rust on the bottom of the fender prevents these bolts from being properly installed, thus the problem you see in this photo. These bolts also have the ability to allow you to pull the bottom of the fender outward to similarly provide clearance. There is also one bolt at the top of the fender that attaches to the door post (you need to open the door to see it). Shims under that tab for this bolt will move the fender outboard at the top, which it also appears to require in this photo.
After removing the fenders, I've discovered that someone has attempted a rust repair welding in an old sign in the lower rear part of the fender. I'll fix that and get it mounted back up after the disc brake conversion and the suspension bushings replacement.
Thanks for the help and insight to both of you.
Congrats on your new toy!. I just bought my first 69 cutlass convertible a couple months ago too. Im working out all the bugs that have plagued the car over the years. Let know if you need me to help on anything, sometime old cars can have missing parts and I can check on my car for ya.
Chris
ros6872
October 30th, 2015 09:41 AM
ros6872
October 31st, 2014 05:04 PM
70SXchris
February 24th, 2012 05:02 AM
70SXchris
March 25th, 2011 09:31 PM
