Testing a fuel gauge and sender on a 1970 Cutlass S
Old Mar 25, 2016 | 12:36 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
My fuel gauge is stuck over full. Just want to know where to start.
Old Mar 25, 2016 | 02:22 PM
I would start by grounding the wire to the sending unit with the key on to see if it goes to E. If it does then the problem is with the sending unit.
Old Mar 25, 2016 | 03:17 PM
Octania's Avatar
There should be a connector to this brown wire in the trunk, about the center L-R, near the grommet that passes it thru the floor.
Old Mar 25, 2016 | 10:20 PM
Thanks guys, gives me a place to start.
Old Mar 28, 2016 | 04:51 PM
kbass72's Avatar
Mine was the same way when i got it. I was told it was most liklely the sending unit. Changed the sending unit, all fixed. Fairly easy to do and the part was'nt that expensive.
Old Mar 28, 2016 | 05:09 PM
Both my 71 convertible and my previous 70 Supreme had this issue. I found it was caused by the wire was loose where it attaches to the sending unit stud. I dropped the tank on the 70 and crimped the push-on connector to tighten it and that cured the problem. On the 71 I just reach behind the bumper, grab the wire, and wiggle it until the gauge starts working. I'm too old and lazy these days to drop the tank for this.
Old Mar 29, 2016 | 01:29 PM
jaunty75's Avatar
Open circuit, either in the wire from the dash to the sending unit, from the sending unit to ground, or a bad sending unit. As noted, the gauge itself can be ruled out as the problem if grounding the wire from the gauge at the sending unit causes the needle to go to E. This would also confirm that the wire between the gauge and the sending unit is intact.
Old Mar 31, 2016 | 06:37 AM
Try to do so many things on this car, I will ground the wire first, if that works I will try Fun 71's easy fix measure while it is on stands.
JPMDaddy
Jan 31, 2020 04:01 AM
joesw31
Nov 1, 2015 05:10 AM
bob p
Mar 17, 2015 08:40 AM
leroycjr
May 16, 2012 09:27 PM
Sues Oldsmobile
Aug 18, 2009 06:23 AM
