wont come out of park
Old Jan 23, 2007 | 08:05 AM
Tod's Avatar
Tod
My sons 86 cutlass supreme SL would not come out of park. I took off the counsell area and disconected the relay that is attached. Now he can shift out of park but then I noticed he does not have reverse lights. Are the reverse lights and this relay I disconected related, or did he probably not have reverse lights to begin with???
Thanks,
Tod
Old Jan 23, 2007 | 05:03 PM
ozoneblue's Avatar
Wink Park relay
Check all Fuses with a test light ,Ign on & park lights on ,If I rember right it is on ACC fuse cig ltr dome Lps door locks
Old Jan 24, 2007 | 03:17 AM
Oldsguy's Avatar
Past Administrator
There should be a switch connnected to the linkage inside the console which detects when the linkage is put into reverse. The wiring should be with the same harness which activates the neutral start switch. Maybe you should put that all back together after replacing the neutral start switch (which I think is the relay you are refering to). I am not really sure how the tranny on those newer cars works as I only have experience with the TH350/400 and their linkages. But, you may need to do that.
Old Jan 25, 2007 | 05:27 AM
Tod's Avatar
Tod
OK - thank you
fast442
Jan 30, 2012 10:19 AM
Green Turd Truck
Nov 22, 2011 05:38 AM
Charlie_brown
May 13, 2010 09:04 AM
70 cutlass s
Jan 1, 2010 06:19 PM
soldier4christ67oldss
Aug 23, 2009 09:19 AM
