windshield wipers run backwards
Old Jun 28, 2018 | 10:54 AM
tonyhuntsberger's Avatar
I recently bought a 1963 f85 which is about 85% restored. One of the problems I have is that the windshield wipers run in reverse, towards the hood.
The guy I bought it from thought it might have been the wiring backwards to the motor, but reversing the polarity just pops the fuse.
I pulled the connecting arm off the back of the motor thinking the linkage might be 180 degrees out, but was unable to rotate it to correct the problem.
I can tell that the wiper motor was removed before they painted, which led me to think it was linkage related.
Has anyone had any experience with this?
Old Jun 28, 2018 | 12:00 PM
svnt442's Avatar
Maybe the arms are installed incorrectly, as in at the park position they are actually supposed to be up.
Old Jun 28, 2018 | 12:30 PM
Originally Posted by svnt442
Maybe the arms are installed incorrectly, is in at the park position they are actually supposed to be up.
Pull the arms off and cycle the motor until it parks. Use a piece of tape to mark where the arms would be on the shafts and cycle the motor again. Do they go up or down? If they still go down, now remove the linkage bellcrank arm from the motor shaft and flip it around. With the arms off, you should have enough motion to get it back on. Cycle the motor to park again and now check the rotation of the shafts. If it looks correct, reinstall the arms.
Old Jun 29, 2018 | 09:15 AM
Thumbs up
Thanks, I pulled the bellcrank arm off, turned it 180, put it back together, and it works like a champ.
66luvr
Jan 2, 2019 12:45 PM
davoaz
Jun 16, 2014 03:39 PM
stocki26
Ninety-Eight
15
Apr 16, 2013 01:12 PM
sweet70oldz
Nov 8, 2012 09:07 AM
4424me
Jan 11, 2012 11:16 AM
