What is this wire?
What is this wire?
Found an unconnected wire while under my 72 Cutlass 350 with 350 THM. It is black and has a round rubber plug/connector (about 1/2 inch diameter) with 2 slits for plug in. One horizontal and one vertical, but it looks like only one slit is wired. I found it along the drivers frame rail while connecting lines to the brake combination valve. I suspect it goes to the transmission controlled spark. Does that sound correct?
