want to build 85 supreme
Old Aug 29, 2007 | 11:33 PM
Franksupreme's Avatar
ok im new here, also to the cutlass scene so, i have a 85 supreme sedan and i would like to know what my options are as far as motor swaps, stock engine building or anything performance.
thankx in advance
Old Aug 30, 2007 | 04:39 AM
Oldsguy's Avatar
Past Administrator
Welcome to our site Frank. I can't help you directly since I am "old school" but am sure you will get some help soon. This is a nice site with lots of knowledge base.
Old Aug 30, 2007 | 08:08 AM
thankx in advance
Two questions: What engine is in it now, and does the car need to pass emissions inspections where you live?
Since the 307 was optional in that car, any small block Olds (up to and including the 403) is a bolt-in that you can do in a weekend. A big block Olds is only slightly more work - mainly different exhaust manifolds and mods to the accessory brackets due to the taller deck height.
Old Aug 31, 2007 | 12:23 AM
well i live in california so yes it will have to pass emissions but i just got it smogged this month so im good for a while but it has the stock 3.8l v6 i dont know the name of it (307, etc...). and can someone tell me or give me a link for info on small blocks, big blocks cause i dont know much about them, but luckly i am currently attending UTI so im learning as i go.
Old Sep 2, 2007 | 07:52 PM
Redog's Avatar
I'm pretty sure any SBO will swap into that bay with no problems like said above.
Get a pair of motor mounts for a 307, 85 cutlass and they will work of the new motor.
Look into classic or antique plates (if this car isn't a daily driver), here in PA (which is the 2nd most strict with emissions in the country, next to CA) these cars are exempt to emissions
Old Sep 2, 2007 | 08:31 PM
Dapapadon's Avatar
Redog, I don't know which states are the strictest. But here in the Portland area of Oregon 1975 to 80 have to pass an idle test and at 2000 RPM's, plus a visual on cat. converter. 1981 to ODB2 have to pass rear wheel dyno on acceleration, decceleration and at cruise speed. No exemptions in the Portland or Medford areas. But you can move and tag the car out of the areas (for now) and be exempt from testing. Oh, the testing is done by the state rather than independent shops (like Calif.) So no sneaking it though a buddy's shop.
Frank, Calif. is a little stricter because everything has to pass a visual inspection. Plus the laws are always changing. I'm pretty sure if the VIN says V6 a V8 will not pass. in Oregon. You might want to check on that in CA before you decide.
Sorry, I din't mean for this to get so long. But I've seen friends and co-workers get rejected by the smog cops.
Don
Old Sep 2, 2007 | 11:43 PM
88 coupe's Avatar
Junior Member
well i live in california so yes ........
Assembly Bill 616 is still alive. If it makes it into law, you are looking at a Smog check every year, beginning July 1, 2008.
Originally Posted by Dapapadon
........ rather than independent shops (like Calif.) So no sneaking it though a buddy's shop ........
Not in CA. Contractors have too much capital invested in equipment and licensing fees. Fines and potential jail time are also a concern.
All test data is transmitted to the DMV computers in real time. If the numbers do not match the VIN/mileage/history, in the DMV database, a large flag is raised. Contractors would rather not have that happen.
Norm
Old Sep 4, 2007 | 06:56 AM
ok so my best option would be to slightly modify the stock engine? any opinons on parts?
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
Lady72nRob71
Dec 8, 2008 10:23 AM
69 442 protour
Dec 9, 2006 09:25 PM
Ringo
Nov 14, 2006 08:13 AM
