Transmission swap
Old May 30, 2020 | 02:16 PM
wdkb's Avatar
Transmission swap
I have an 86 cutlass supreme with the 5.0 in it. It currently has the 3-speed trans and I would like to convert it to a manual transmission. Any suggestions as to which I would use?
Old May 30, 2020 | 05:37 PM
pettrix's Avatar
There would be extensive & expensive $$ amount of work needed to put a manual transmission in this vehicle.
Why not just put a 2004R (4 speed overdrive) trans in the vehicle? It would almost be a direct bolt-in.
Old May 31, 2020 | 11:44 AM
Bubba68CS's Avatar
There are a lot of posts over on gbodyforum.com that go through various manual transmission swaps available for your platform. This forum skews heavily towards automatics.
Not sure if the 307's have the same issue as earlier Olds V8's, but I'm guessing they are also not drilled for a manual transmission pilot bearing. That's a fairly large barrier to entry on a manual trans swap if you don't plan on removing the crank for a rebuild. If you are rebuilding your engine, or just removing it from the car, it's not that difficult for a machine shop to machine the correct bore into the crank for the pilot bearing and input shaft clearance. I just had that done on the engine I'm building.
Old May 31, 2020 | 02:54 PM
therobski's Avatar
x2 I agree, chime in on a Buick GN forum tons of info...I have a modified 200-4R in the 64.
Old May 31, 2020 | 07:22 PM
wdkb's Avatar
Okay so the car needs a new trans anyway ( I'm getting a metal scraping sound whenever it tries to shift to second) is the trans I should be looking the 200-4r? Or should I be looking for something else? Thanks
Old Jun 1, 2020 | 02:00 PM
android 211's Avatar
The cheapest thing to do would be to get a Muncie, a Parts Place manual transmission conversion kit or a hydraulic clutch kit. You'll need a shifter and a bellhousing. The rear of the crank has to be drilled or you can cut off the input shaft and use a conversion pilot bearing. You'd need a clutch and a flywheel too. It could come to over two grand in parts alone.
Old Jun 1, 2020 | 02:51 PM
JohnnyBs68S's Avatar
IMO, I wouldn't bother swapping a MT behind that 307. I'd LSx / T56 it. Sure, more buck$, but WAY bigger increase in fun. Short of that, just rebuild the 3-sp AT unless you want to swap rear gears to 3.90-ish, then I'd go 200-4R too.
Old Jun 2, 2020 | 03:40 PM
pettrix's Avatar
The manual trans swap doesn't make sense. Just go with a 2004R. It was a factory option back then with an 86 Olds Cutlass. All 1985-1987 Olds "442" had a 2004R trans
zeeke
Site Suggestions
Jun 1, 2020 07:39 AM
LMC
29
Dec 24, 2015 05:40 AM
beachmont
Jun 5, 2015 08:10 PM
1969442FREAK
Feb 20, 2011 03:43 PM
marine90
Apr 3, 2007 09:12 AM
