thermostat housing
Old Feb 28, 2008 | 05:22 PM
projectheaven's Avatar
thermostat housing
Hello.I just installed chrome valve covers,chrome air cleaner and a chrome thermostat housing on my 350 rocket.
The problem i'm having is I couldnt use the old thermostat neck and I dont know what to do about the connection from the water pump to the thermostat housing.I tried a 3/4 hose but it has a crink in it because of the angle.
Any suggestions???
Old Feb 29, 2008 | 06:50 AM
The factory used a molded, "J"-shaped hose.
Old Mar 1, 2008 | 11:06 AM
boese1978's Avatar
If you have the old one take it to a parts store, I had to replace mine on my '68 S, they let me go in back and look for a similar ID hose with the approx bend, I had to cut 2" off of one end and about 6" off the other but it worked out great.
Steve
Old Mar 1, 2008 | 03:15 PM
rocketraider's Avatar
Oldsdruid
Make sure you seal that chrome gooseneck up good. I've never seen one that didn't leak. Usually have to sand 'em on a piece of plateglass to scuff and true them up enough to seal. Same thing with almost any aftermarket chrome accessories.
Old Jul 3, 2019 | 06:29 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I would run a 160 Robert Shaw thermostat, some thermostats can be restrictive in flow. It sounds like a low speed air flow issue. Does it have a 7 blade fan, good clutch and shroud? Was a closed impeller water pump used on this motor? I noticed 0 difference on the riveted plate Flowkooler but others with the new cast closed impellers claim a noticeable temp drop.
Old Jul 3, 2019 | 06:56 AM
What was wrong with cleaning up the OEM T=stat and using it? Good part and easy connections with the straight bypass hose.
Old Jul 3, 2019 | 07:16 AM
70cutty's Avatar
Beer Connoisseur
This is what I used. bypass hose
White_Knuckles
Jun 21, 2023 05:52 AM
76olds
Jan 28, 2019 07:03 PM
transam79
Dec 30, 2012 07:31 AM
rhaberm
Aug 18, 2012 10:06 PM
projectheaven
Mar 15, 2008 10:21 AM
