Stupid Purchase
Old Oct 29, 2017 | 09:38 AM
babailey's Avatar
Stupid Purchase
I purchased two 1967 Outside Mirrors assuming I could put one on the passenger side. I even drilled the holes on the passenger side before I realized that I can not turn the mirror far enough down (it impacts the post) to make it useful.
I started to buy a pair of the 1968 mirrors but then I noticed that they attach with screws from the inside of the door skin, so I'm afraid to make another purchase till I learn more.
So, my question. Have any of you guys added a mirror to the passenger side and, if so, what mirror(s) did you use.
Thanks!
Old Oct 29, 2017 | 09:59 AM
The passenger side mirror was a dealer installed option on the 1967 cars. It is NOT the same P/N as the driver side mirror.
Old Oct 29, 2017 | 10:09 AM
babailey's Avatar
Any idea on what that part number might be? OPGI and Fusick both say they only have driver side.
Thanks!
Old Oct 29, 2017 | 10:19 AM
Thanks!
P/N 230365 is the RH outside mirror package for the 1967 A-body cars. Fusick used to repro these, but no longer does. I got one from them years ago. The LH outside mirror is P/N 230368.
Now here's an interesting bit of trivia. The parts book shows that the outside mirrors on the 1967 full size cars are the same on both sides - also P/N 230365!
Old Dec 5, 2017 | 10:39 AM
sschevellecutlass_Bob's Avatar
You are not alone. I did the same thing with my Chevelle. Looks good but that's it! Cutlass mirrors are both usable!!
Old Dec 5, 2017 | 10:46 AM
FWIW, those loveery 69 H/O mirrors are totally useless
Old Dec 5, 2017 | 06:45 PM
steverw's Avatar
Ill have to admit i made the same purchase with 2 driver side mirrors, but i did not drill any holes before i discovered it wont work. So i have an extra mirror for someday.
Steve
Old Dec 6, 2017 | 03:12 AM
BeenThere's Avatar
1967 Olds Cutlass 442 R.H. mirror
Also look for Oldsmobile part number 982858. It was the dealer installed passenger side mirror package.
Old Dec 6, 2017 | 03:46 AM
35tac's Avatar
Not to high jack this but would this be the same for the 66 Cutlass?
Wayne
Old Dec 6, 2017 | 03:59 AM
tru-blue 442's Avatar
Old School Olds
Wayne, here's a 66 repop.
https://www.ebay.com/itm/1966-Oldsmo...wAAOSwmtJXVghx
Old Dec 6, 2017 | 04:28 AM
35tac's Avatar
Thanks, I am aware of that but I have the same problem of adjusting the right side (passenger) to see something from the drivers view. However maybe the intention in 66 was not to avail that view for the driver as opposed to the passenger. Interesting that 67 had a right and left part number. I haven't found a part number if any for a right (driver) and left (passenger) side. Nor is there a mention of right and left in the assembly manual and I also checked the 66 Fisher Body Manual.
Interesting topic.
Wayne
Old Dec 6, 2017 | 05:02 AM
The rh sideview mirror is not intended for the passenger.
Old Dec 6, 2017 | 05:23 AM
35tac's Avatar
I assumed that also, however my passenger side mirror will not adjust enough to be used by the driver. I have yet to find reference to positioning or adjusting either driver or passenger side mirrors. No reference of dimensions in the 66 assembly manual, 66 repair manual or 66 Fisher Body manual. That probably would help.
Wayne
Old Dec 6, 2017 | 04:34 PM
Yellowstatue's Avatar
Mirror Package, outside rear view/accessory/ PN 982750 1966/all-manual-RIGHT. PN 982858 1967/all-manual-RIGHT as per MPC #743A (the Yellow Pages)
Old Dec 7, 2017 | 08:00 AM
Tedd Thompson's Avatar
Just a thought, has anyone ever placed a 3+ inch stick on bubble mirror like what the truckers use and see if there is enough curvature and adjustment to see behind from the drivers side? I did this on my 55 to eliminate blind spots even though the mirror had enough adjustment as installed. I have never regretted it... Tedd
Old Dec 7, 2017 | 09:46 AM
425HP409's Avatar
Restorer
My 442 came with a factory remote mirror on the left side. I always install passenger side mirrors (I usually have to buy drivers) on my cars with them usually working OK. I have someone hold them in place while I sit in the drivers seat and make sure that they can adjust and not interfere with the vent window operation.
The one that I put on my 67 442 works just fine. I believe I bought it from Fusick. Here are some photos of mine. Sorry about the cockeyedness of them.
Old Dec 7, 2017 | 02:12 PM
I put a three inch stick-on on my '57. Now it's a whole new world over there.
Old Dec 7, 2017 | 02:16 PM
35tac's Avatar
If the repo mirror that Fusick sells for the 66 F85/Cutlass is correct and can be used for the passenger side also, given that the adjustment capability is the same, how can the driver make use of the passenger side mirror without a change in position on the door?
That is all I am trying to figure out. My car has a mirror on both doors already. I don't know the history of the mirrors. I just can't adjust the passenger side mirror to make it useable when I am driving. Thanks for your patience.
Wayne
Old Dec 7, 2017 | 05:10 PM
425HP409's Avatar
Restorer
It was a drivers side that I installed on the right side.
auto_editor
Apr 26, 2013 05:19 PM
MDchanic
Mar 27, 2012 07:54 PM
Tedd Thompson
Sep 24, 2010 07:32 AM
gearheads78
Dec 18, 2009 06:15 AM
DonFrost
Jan 6, 2007 06:47 AM
