service lights
Old Aug 21, 2014 | 07:14 AM
cutlass-Boy-82's Avatar
service lights
I have a 1982 Oldsmobile cutlass supreme. And my check engine light keeps coming on. It did not start coming on till I switched the fuel pump. How do I reset the service light. Or get it to go off ?? Please help
Old Aug 21, 2014 | 10:18 AM
jaunty75's Avatar
Disconnecting the battery and then reconnecting it after a few minutes might clear it. I've had success doing this on some cars over the years. But if the problem is still there, it'll just come back on again.
If it does, you might go to Autozone and have them read the code for you. They'll do it for free. Other stores might, also, but I don't know which ones.
Old Aug 21, 2014 | 12:36 PM
I've d
Old Aug 21, 2014 | 12:37 PM
I've done that before. And I took it to AutoZone and they says my car was to old to hook up to tge computer
Old Aug 21, 2014 | 03:34 PM
Octania's Avatar
easy fix:
Old Aug 21, 2014 | 03:44 PM
RetroRanger's Avatar
72 Olds CS
do you have the owners manual or a service manual, my old 80s ford would show codes w an analog voltmeter you counted the sweeps and the # corresponded to a failuremode. if you knew why it went on it mught be easier to shut it off ?
Old Aug 21, 2014 | 05:56 PM
Lady72nRob71's Avatar
First off check everything around the fuel pump for issues, like broke or disconnected vacuum hoses. It is easy to break or disturb something since the fuel pump is hard to get to on these cars. I assume you have the 307?
If that does not work, pull the codes as described here:
http://tlentz.oldsgmail.com/howto.html#Computer
Let us know what you find...
Old Aug 23, 2014 | 06:49 AM
I checked everything . It's all fine nothing the disturbed. And its a 4.3 L 260
Old Aug 23, 2014 | 09:31 AM
72 Olds CS
What's the code ? You can get it from robs post above
65droptop442
May 5, 2013 12:21 PM
69442murph
Mar 25, 2013 07:59 AM
devmar07
Feb 23, 2012 04:40 PM
oldstuff
Sep 13, 2011 08:03 AM
Sid
Sep 10, 2010 02:33 AM
