Rocker molding removal
Old May 25, 2015 | 02:15 PM
Wbland's Avatar
How do you remove the rocker molding on a 1972 Cutlass Supreme? Any advice will be helpful. Thanks
Old May 25, 2015 | 02:54 PM
oldstata's Avatar
Justin
If I remember correctly, there were screws holding the ends in the wheel wells and you pull forward as there is round washer screwed to the rocker that you slide it down.
It's been over ten years so maybe some one will chime in to confirm.
Old May 25, 2015 | 05:06 PM
VI Cutty's Avatar
If you mean the wide chrome strip, it's bolted/screwed by tabs under the rocker. Remove the fasteners then slide the strip up to clear the mounting brackets.
sgtoro
Apr 8, 2012 09:08 PM
CutlassLegend
Sep 21, 2011 02:56 PM
denf221
May 12, 2010 06:13 PM
wiseguy58
Feb 24, 2010 11:07 AM
davesdelta
Apr 7, 2009 03:20 PM
