Rear wheel trim for 70 olds cutlass coupe
Old May 17, 2011 | 06:41 AM
orthoK's Avatar
HI All
I've put this in the body and paint section as well- managed to scrape the right side of the car and have damaged the trim for the right rear wheel arch and also the short straight trim in front of it (behind the door). I need to get a replacement, would ideally like to order a new made part for both if there is somewhere that does it.
Does anyone know of any good websites for people that would fabricate these two parts? Thanks in advance
Russ
Old May 17, 2011 | 06:55 AM
stevengerard's Avatar
I beleive both are reprodiced now, try www.fusick.com or www.thepartsplaceinc.com
Old May 18, 2011 | 07:21 AM
orthoK's Avatar
Thanks Steven, great link. have found the wheel arches for the rear wheel. Haven't found the other piece of trim, not sure what to call it. It sits on the panel just in front, straight metal piece (20cm) with rubber strip running through the middle. What do you call this part? I'd just normally call it the door trim here but no luck on the webiste.
5998DownUnder
May 10, 2013 08:22 PM
robvrobv
Feb 18, 2013 04:32 AM
terrapin
Jan 11, 2013 04:52 PM
Jaybird
Nov 19, 2011 01:57 PM
orthoK
May 16, 2011 10:10 PM
