Rear view mirror wiring
Old June 23rd, 2014, 05:46 AM
70CutlassConv's Avatar
I have a 70 Cutlass convertible with a map light on the bottom of the mirror. The wire running to the light is bad. Anyone know how I can get inside the mirror to rewire it?
70CutlassConv is offline
Old June 23rd, 2014, 07:19 AM
Likely you'll have to remove the grey mirror trim and then the mirror glass to get inside the case itself. Are you sure it's the wire and not the bulb that needs replacing?
Allan R is offline
Old June 23rd, 2014, 08:08 AM
Thank you for your reply. I have a dead short in the car on that circuit. The wire as it goes into the mirror has the insulation worn off
Old July 27th, 2014, 05:35 AM
I lust had mine apart. The wire has a snap in "bullet" looking connection that will pull out of a plastic socket on the top of mirror. I used a pic and gently got it out of the socket. Then under the mirror you can grab the plastic lens with you fingers and work it off. Then you can squeeze the slider switch in the middle where the lens was and release the whole switch. Then you can see its just a simple brass contact that grounds on one side as you slide the switch to the mirror case, and slides over the "bullet" on the other side. Its a lot easier to do this on a bench w/mirror out of car. Mine wasn't working but just needed cleaning up now works good.
Greg Rogers is offline
Old July 27th, 2014, 07:06 AM
oldspackrat's Avatar
Just be careful with the gray plastic slider as they become brittle with age. I have extra mirror map light parts if you do you need anything.
oldspackrat is offline
Old July 27th, 2014, 07:12 AM
It's a lot of work to remove the mirror wiring intact from its Fisher connection under the left side dash. Did you cut the gray wire and then work on the bench or did you already have the interior dis assembled? Last one of these I removed, the front windlass, front headliner and left side A pillar had to come off.
Allan R is offline
stevengerard
December 31st, 2009 04:01 AM
roy341
July 11th, 2009 05:27 PM
tim72
April 9th, 2009 05:33 AM
64 Olds Dynamic 88
April 27th, 2008 06:53 PM
<diablo76delta88>
September 11th, 2003 08:41 PM
Quick Reply: Rear view mirror wiring
