Rear 1970 Quarters
Old Mar 7, 2011 | 04:00 AM
smietana's Avatar
Rear 1970 Quarters
Posted this in bodywork section, but have not heard anything.
Will the quarters fro m a 70 coupe, not fastback. Fit same year convertible?
Old Mar 7, 2011 | 04:33 AM
Bluevista's Avatar
Registered
The Mill Supply listing for them says that the quarters fit the Cutlass convertible and the Cutlass Supreme (non fastback style).
http://www.millsupply.com/
Old Mar 7, 2011 | 04:34 AM
stevengerard's Avatar
correct supreme and convertible are the same
Old Mar 7, 2011 | 04:40 AM
oldsconv's Avatar
The quarter skins would be the same hardtop of conv sincce they only over 80%, but obviously, full quarters are different between hardtop and conv. It looks like you have a convertible - why not buy the full conv repros which are only $400 each (vs $250 for skins) and MUCH easier to install as you won't have a long horizontal weld like you would with the quarter skin. I bought the full ones for my car and they worked great.
Old Mar 7, 2011 | 05:25 AM
smietana's Avatar
Thanks for the quick reply guys, I was looking at a donor car in Arizona. It has good front fenders witch I need plus interior. Trying to see how much of the car I can use for mine.
Old Mar 7, 2011 | 05:37 AM
Bluevista's Avatar
Registered
I wonder if that long horizontal weld and the way it was attached in other places was the reason the quarter tore off that smashed Cutlass like it did?
Old Mar 7, 2011 | 06:39 AM
Rickman48's Avatar
Yes, that's the reason!
Full qtrs. include the striker pate, lower window, some of the sail panel, trunk edge, and the taillight pocket to the rear body panel.
Much stronger for a hit like that!
Looks like sloppy installation on the crashed car!!
Old Mar 7, 2011 | 06:51 AM
smietana's Avatar
The reason I was looking for a donor, was everyone was saying how after market body panels need a good amount of work to fit?
Old Mar 7, 2011 | 01:39 PM
bil's Avatar
bil
It also looks like a sloppy de-installation! Sad picture! ---bil
Old Mar 12, 2011 | 04:39 PM
70convert's Avatar
where are you getting full quarters for $400. seems like there all around 500 plus.
Old Mar 12, 2011 | 05:46 PM
oldsconv's Avatar
Tamraz. But I guess it was 3 years ago and price went up. Either way the
Partial skins fit conv and hardtop but you have a long weld that will eventually
Show thru the paint IMO. Some repros are crap but The full repros for this 70-72 conv application fit very decently with just minor tweaking. The bonus is that the seams are all hidden where you weld (doorjamb and trunk w-strip channel, etc). Only weld visible is the 5 inches at top of quarter between trunk and conv top well. This was originally leaded at the factory but my painter welded a solid plate there.
Unless you are a good welder for the repro skins I liked the full full quarters as I am an amateur and installed them myself fairly easy. To me, Worth the extra money for much less hassle.
Old Mar 13, 2011 | 08:16 AM
Rickman48's Avatar
If you were having a shop do the install, they'd probably charge an additional 5-10 hours, per side, for the partial qtrs, as you've a long cut, fitting and welding, and then long bondo to finish!
At $40-$50 an hour - the full qtrs. are a much better deal - both in fit and finish, let alone price!
Dan-o
Oct 16, 2008 10:08 AM
danlonchar
Jun 21, 2008 12:31 AM
Topless72
Jan 9, 2008 06:11 PM
Stacey
Mar 11, 2007 03:47 PM
