Rallye - what black to use on Grilles
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
I'm doing a quick freshen up on my Rallye and want to know what black to use on the grilles, tail lights, headlight bezels, etc. Is it a flat, semi-flat or gloss black? Any one have a recommendation on what rattle can paint to use? Thanks in advance for the advice.
I'm partial to Rust-Oleum Satin 7777 Black. In addition to being acceptable as a correct semi-flat, this stuff comes in a poof-can, and has much better adhesion than, say, Krylon 1613 Semi-Flat Black. The downside is its slow drying time. I usually allow it to dry overnight.
I've been using Krylon 1613 Semi-Flat Black for years and I'm very happy with it. They've recently changed the name and number to 51613 Satin Black and it has a little more of a shine/sheen to it but it's by no means glossy. I use it on just about everything black...frame, under the hood, metals, plastics, trim, etc and it looks excellent and very factory. It holds up very well and applies easy just like the can says. Drying time is also pretty minimal. I haven't done grilles yet but I would definitely use this paint to do so.
Thanks,
Bob
I've had some luck with Rust Oleum but mostly just the primer. I've never gotten quite the same results or satisfaction as with Krylon. Whatever it is in the formula of that paint always yields excellent results for me. Of course a lot of the results come from the prep and painting conditions too!
Ragtop,
It was a rattle can, but I've had it happen several times. A week later it is still tacky. Maybe I put too thick a coat on, or something, all I know is I avoid it now. Krylon works for me and that's all I use, if they have the color.
I do not love the fact that they changed their black gloss levels, though.
The Semi-Gloss Black, Semi-Flat Black, and Ultra-Flat Black, were all darn near perfect for their intended applications.
Now, there is nothing flat enough for a real dead flat, and the semi-gloss just isn't the same for engine parts, etc.
Anyone know where I could find a case or 2 of the old stuff?
I agree. I believe that the adhesion is not as good as the old stuff as well. I've had great results with the Rust-Oleum. It's been used extensively on my GTO (pic attached), Best of Show, Haydocy Pontiac All Pontiac Show, 2010 (no brag, just fact. Well, maybe a little brag...).
I love Krylon and have been using it for years.
On a whim, I thought I'd check ebay for you and I actually found a listing for some 1613...check it out:
http://cgi.ebay.com/KRYLON-PRO-SEMI-...item27b5e1ff57
it's a little pricey for 6 cans but if it's what you really need.....
hope this helps.
John
August 22nd, 2019 08:45 AM
JpMotorsports
May 15th, 2014 07:08 AM
Oldssupreme
February 3rd, 2013 06:24 AM
