Questions about tranny and motor.
Old September 28th, 2006, 05:19 PM
t_visker's Avatar
I am wondering if my TH-2004R will bolt up to my 69 olds 350 crate motor, and if not is their a way that I can, etc change the bell housing?
P.S. my car is an 87 cutlass supreme brougham came with the 307 cid
t_visker is offline
Old September 28th, 2006, 06:47 PM
coppertopgmc's Avatar
The 350 oldsmobile and the 307 oldsmobile both have the BOP bell housing pattern so your trans should bolt right up. also i think some of the transmissions around that year had the BOP and GM pattern to bolt up to olds,buick,pontiac,cadillac and also chevrolet
coppertopgmc is offline
Old September 28th, 2006, 10:22 PM
t_visker's Avatar
thanks
well today we had 2 hrs to work on it and all we have left is taking off like 3 transmission bolts and its ready to be pulled on the cherry picker and my shop teacher walks in flippin out about the motor is to old it wont bolt up blah blah .. so i figured it would work im just double cheking..
thank you
t_visker is offline
Old November 22nd, 2006, 03:54 PM
cutroc350's Avatar
Like coppertop said the engine and trans will bolt right up. The outside measurements and bolt patterns are the same for most of the Olds small blocks. It sounds like your shop teacher needs to be the student this time!
cutroc350 is offline
Fb auto
January 8th, 2015 01:45 PM
Adrian Lawrence
November 16th, 2010 10:14 AM
rfaller
July 31st, 2008 09:23 PM
Arrowstorm
February 9th, 2007 02:30 PM
seth garrison
July 9th, 2006 05:22 PM
Quick Reply: Questions about tranny and motor.
