Problem with Air Ventilation
Old Aug 29, 2016 | 10:29 AM
Cutlass-S's Avatar
Hi Guys,
after revising engine valves at the Oldy Garage there are a strange problem with the ventilation:
Air no longer comes from the upper air nozzles - the whole Air is blowing over the lower vent in the middle. The Blower Motor ist working but I guess there is a flap in the heater/defroster core who is no more open.
Any tips of you specialists?
Regards from germany...
Old Aug 29, 2016 | 12:06 PM
Originally Posted by Cutlass-S
Hi Guys,
If this car has factory air conditioning, the doors inside the HVAC box under the dash are operated with vacuum diaphragms. The hose that provides this vacuum from the engine apparently didn't get connected properly when the valves were done.
Old Aug 30, 2016 | 07:48 AM
Cutlass-S's Avatar
Thanks for giving this hint...
Seems I have to open this Box to look after the flaps & vacuums
All hoses are connected on carburator and engine..
Whatever - where is the screw gun?
Best Regards
Old Aug 30, 2016 | 08:12 AM
I doubt it. If the system was working before the valve job and now is not working, the chances that the problem is inside the HVAC box are nearly nonexistent.
You can waste your time disassembling it or you can do some troubleshooting first and avoid that headache. The fact that hoses are connected doesn't mean that they are connected correctly. Have you checked for vacuum at the actuators under the dash when the controls are set? Your Chassis Service Manual will tell you which actuators get vacuum at each control setting.
Old Aug 31, 2016 | 02:05 AM
Cutlass-S's Avatar
OK. So I'll check first the controls...
Thank's for guiding!
Regards
Karsten
Doc350s
Nov 4, 2011 05:42 PM
charlierogers
Apr 3, 2011 07:18 AM
Snowdog
Apr 11, 2009 11:43 AM
ct1979
Oct 13, 2008 10:44 AM
iuhoops83
Aug 2, 2007 11:22 AM
