Positive Traction
Old Mar 9, 2008 | 08:26 PM
Newkid8's Avatar
Positive Traction
What sort of positract would a 1970 Cutlass "S" with the 455 engine need? Especially if it is going to be used for drag racing.
Old Mar 9, 2008 | 08:38 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Drag racers use lower gearing like 3.73, 3.91 or 4.11
The motor runs at higher RPMs with lower gears.
The higher the rpm, the more Hp it's pushing, blah blah etc etc.
Bottom line.... they only have 1/4 of a mile to squeeze as much juice as they can out of the lemon.
It's easier to get there if you hit the ground running instead of walking.
Old Mar 10, 2008 | 08:07 AM
Chaney3000's Avatar
Eaton posi with some Richmond gears (3.73 or 3.91 or 4.11). If you plan on just using it as a drag car go with the 4.11
3.73 will give you a little more streetability out of the vehicle.
Old Mar 11, 2008 | 10:32 AM
buzzbomb's Avatar
Go for a 3:42 gear and if you need more put smaller diameter tires or slick on it like a 25" and that will give you an effective ratio of about 3:70 or so and when you drive it on the street use the standard 26.5" tire for the true 3:42 ratio
Old Mar 11, 2008 | 04:49 PM
Newkid8's Avatar
Is there a certain brand I should get? Are there brands I should not get?
Old Mar 11, 2008 | 07:52 PM
Go here and contact Jim.
Most helpful rear end builder on the Olds/Buick forums.
http://www.jdrace.com/about.htm
travisbeamon
Drivetrain/Differentials
Nov 29, 2012 07:12 PM
coppercutlass
Suspension & Handling
Jul 27, 2011 05:56 PM
Redog
May 30, 2008 02:45 PM
Redog
May 13, 2008 07:41 AM
