1963 F-85
Old Feb 28, 2008 | 02:04 PM
nigelf's Avatar
1963 F-85
Hi,
I'm looking for parts for a 1963 F-85, most of the sites I've found list parts from 1964. I especially need a new center link or, preferably, just the two end pieces where the Pitman and idler arms fit.
I also need the drive gear in the gearbox that drives the speedo cable. It's a 3 speed hydromatic 'box.
Any hints of places to look will be gratefully received.
Regards,
Nigel
Old Feb 28, 2008 | 02:20 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
http://www.kanter.com
Old Feb 28, 2008 | 02:32 PM
nigelf's Avatar
Thanks, but they only list 1964+ and the 1963 center link ends are different. Same with Fusick and YearOne.
Regards,
Nigel
Old Feb 28, 2008 | 03:26 PM
Rallye469's Avatar
Did they share steering components with the '63 Pontiac tempest?
You may have better luck shopping for the assembly by cross checking
other cars -OR- different years if they they are interchangable.
good luck
Old Feb 28, 2008 | 03:47 PM
Unfortunately, the 61-63 cars are completely different from the 64-up cars and are not anywhere near as popular, so replacement parts are very difficult to get.
Old Feb 28, 2008 | 03:51 PM
Maybe an Impala?
I think some of those parts may swap.
Old Feb 28, 2008 | 06:51 PM
Try Buds Auto
1-580-463-2424
and www.allamericanclassics.com
Old Feb 29, 2008 | 06:53 AM
Originally Posted by J-(Chicago)
Maybe an Impala?
Uh, not even close. The 61-63 GM small cars (F-85, Skylark, and Tempest) are all based on the Corvair (yes, Corvair) platform. It's interesting to note that the Corvair was rear engine with rear transaxle, the F-85 and Skylark were front engine and trans with conventional rear axle, and the Tempest was front engine with the Corvair transaxle. I'm going to guess that the Olds, Buick, and Pontiac all used the same front suspension. I don't know if the Corvair parts interchange or not.
Old Mar 2, 2008 | 01:23 PM
speedy_87ss's Avatar
I also just purchased a 63 Cutlass/F85. Yes, finding parts is a challenge, but made easier for me personally #1, being in the auto salvage industry, #2, I have no intentions of restoring the car to original. It's going the route of 4 wheel disc brakes, tubular Z28 front sway bar, matching rear sway bar, 9" rearend, 403 engine with 2004r trans. Although I intend to keep the body and interior 100% stock looking with the exception of wheels and tires, and if I find some type of mild hood scoop that could look good enough to appear as if factory installed.
If you DO locate parts sources, please share!
Jeff
Old Mar 2, 2008 | 04:55 PM
88 coupe's Avatar
Junior Member
........ F-85 and Skylark were front engine and trans with conventional rear axle ........
Except for the trans and 215 engine, F-85/Cutlass and Special/Skylark were mechanically identical.
Norm
Old Mar 3, 2008 | 10:23 AM
Norm
Norm,
I'm aware of the differences between the Olds and Buick versions of the 215, but what were the trans differences? And of course, both offered the 198 cu in version of the Buick V6 as well.
Old Mar 3, 2008 | 10:40 AM
nigelf's Avatar
Now that is very interesting. Thanks 88 Coupe.
Old Mar 4, 2008 | 07:41 PM
88 coupe's Avatar
Junior Member
........ what were the trans differences? ........
I should have said automatics.
3 and 4 speed manuals were the same. Special/Skylark were Buick 2 speed, f-85/Cutlass/Jetfire were Olds (GM?) 3 speed. All had yokes fixed to the tailshaft and a two piece driveshaft, separated by a constant velocity/slip joint arrangement.
Norm
Old Mar 4, 2008 | 07:58 PM
Yes, an interesting driveline setup. I did get the transmission and 2 piece driveshaft with my car. Won't be needing it, any takers?
Jeff
Old Mar 11, 2008 | 09:41 PM
goodkarmech's Avatar
For the steering parts, try this place:
http://www.rareparts.com/
Good luck!!
Old Mar 12, 2008 | 05:17 AM
nigelf's Avatar
Thanks, they had them in stock, but Kanter.com is a lot cheaper.
The driven gear for the speedo is missing: is there anyone who can give me some details about it i.e. part number, number of teeth, dimansions, colour etc? It's for a Hydramatic 3 speed transmission.
trackz man
Aug 29, 2016 04:32 PM
louie62
Jan 26, 2006 03:35 PM
<RUREDDY2GETSUM>
Feb 17, 2005 03:16 AM
chuck2
Jan 12, 2005 02:11 PM
wackado213
Sep 12, 2004 08:22 PM
