performance upgrade
Old December 18th, 2006 | 05:33 PM
sean000's Avatar
performance upgrade
I have an 83 Olds Cutlass Supreme Brougham 4 door, with a 3.8L V6. I want to get a few more ponies out the 3.8L, but can't find any aftermarket add-ons. Does anyone have any ideas of things i can do to my 3.8L. (cold air intake, supercharging, etc..). Any ideas would be greatly appreciated.
Thanks in advance.
Old December 19th, 2006 | 11:50 PM
Redog's Avatar
Pull the 3.8 and drop a 455 or a 350 olds in it. 3.8 isn't worth hopping up
Old December 20th, 2006 | 12:55 PM
2 door cut's Avatar
im in the same boat as you sean..... i want more out of my **** but its just so slow.... im also told that i would have to do a lot of work to put in a 350 or even a 305 ... what would i have to do exactly?
Old December 20th, 2006 | 03:14 PM
69oldsguy's Avatar
First you have to put the 350 on a chain hoist and get it about 6 ft. off the ground, then you roll the '83 out into the south forty, then you roll a 68-72 underneath, lower the 350 and your in business. What can I say... I'm partial to A bodies. Have fun guys. That's why were all gearheads.
Old December 20th, 2006 | 03:29 PM
Redog's Avatar
I have a 85 Delta 88 with the 307, I'm doing very little work to the motor, just enough to keep it running. In a few years, in goes a Olds 350 and the fun will being
Old December 20th, 2006 | 08:06 PM
sean000's Avatar
Hey thanks for the help..."gear brains"...i mean "heads"
I have been looking around and there are some things you can do to the V6 like turbocharging/supercharging to start. Im going to try to find out more, and will let you know.
Old December 21st, 2006 | 04:11 PM
Snakebite's Avatar
Cool Its An 83
Its an 83 Cutlass Full-size just dump a 350 or 305 its fit with the turbo 350 trans. they came with those so it shouldnt be hard to find one that will give it some pick up. or build your own or custom v8 and slam it in then it will rock out with its **** out.
Old December 22nd, 2006 | 11:52 AM
sean000's Avatar
Thanks for the info. Good to know I can keep the same tranny and put a 350 in. Would like to do that one day, but for now am going to tune up this V6 as much as I can and see what happens.
Old December 22nd, 2006 | 05:45 PM
mjscutlass's Avatar
buy my car
Here is an idea just buy my car and take the 455 out and put everything in ur car. Everything is there to swap it over. It depends on how far u are from me.
Old December 22nd, 2006 | 07:41 PM
elmo's Avatar
The last time I went into a Buick V6 it cost a bundle. Was a 79, even fire with the newer style heads. It ran darn good, but for the price I could have had a V8. But hey, that was 20 years ago. The Buick V6 takes up alot of room, but is infamous for the Grand Nationals success with excess mods and lots of $$. I would change out to a V8 or consider a 4.3 if you insist on a 6. Lots of folks are dumping thier 307's, and they are a darn good engine. Anyone ever used the roller 307 with a TBI from a 305 truck?
wmachine
December 30th, 2009 06:55 AM
Jolly Green
February 13th, 2008 01:33 PM
bcg88
January 17th, 2008 12:35 PM
LMHConcepts
January 4th, 2008 01:55 PM
bcg88
July 15th, 2007 07:06 PM
