No brake Lights
Welcome!
Do the turn signals work? If so then suspect the brake light fuse (replace or test with a meter, don't just look at it). If thats good, jump the brake light switch at the pedal. If that makes them come on, then replace the switch.
Agree with wonderboy24, check your break light switch. Could be stuck or just bad (they always seem to go out at the worst times...). Might check your wires for breaks or chaffing. Could be grounding out. Good luck!
oldstuff
September 13th, 2011 08:03 AM
Del70
August 2nd, 2011 04:40 PM
