New to the Site My 1970 Olds
Old Feb 17, 2008 | 12:35 PM
branchman88's Avatar
Old Feb 17, 2008 | 12:50 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Welcome, Branchman. Sharp car. Looks like you have some overtime to work. Get that rust stopped asap. Lots of good info and people on here. Enjoy.
Old Feb 17, 2008 | 01:32 PM
and whats the best way to go about getting rid of that rust??
Old Feb 17, 2008 | 04:27 PM
rocketraider's Avatar
Oldsdruid
On the decklid, get another one. You could cut that rust out and I can almost guarantee within a couple years it'll be back. Still plenty of cars in dry areas of the country, and you'll spend the same money fixing rust as buying a rust free decklid.
Wheel arch area- patch panels. This is another area that tends to come back, so make sure you clean and seal the outer wheelhouse area too. Repro quarters are available, but you may have to do a lot of fitting to make them fit and look right.
Edge of vinyl roof- remove the top and moldings, mask the glass good, then sandblast the rust off. It looks like mostly surface rust, but be prepared for the sandblaster to find holes you didn't think were there.
All these are common rust areas on these cars, so someone, somewhere has learned how to fix it.
Hood tooth and moldings should be fairly easy to find. Once yer Cutlass has its tooth again, you may wish it didn't. Back of my head has a bunch of scars from Cutlass (and big Olds) hood teeth.
I recommend buying a 1970 Olds Chassis Manual, Fisher Body Manual, and an Assembly Manual. These will show how to remove/install all the moldings and how to disassemble and reassemble the car. Plus there's wiring diagrams and factory procedures- and believe me having one is sometimes the only way to figure out how to do something on these cars.
Old Feb 17, 2008 | 08:41 PM
dar83501
Guest
Posts: n/a
My body man told me once of a product you can slather on over paint but I forgot the name of the stuff...it takes about $80 to coat a vehicle but it apparently prevents it from rusting farther.
I haven't used it, don't remember the name, and can't verify if it's worth wasting money on or not, so that's not terribly helpful...
Old Feb 18, 2008 | 05:43 PM
Thanks man!!!!!!
Old Feb 19, 2008 | 05:07 AM
Oldsguy's Avatar
Past Administrator
I like the painted top on your car. Gold/white is a nice color combo, do you plan on keeping that? Welcome to our site.
Old Feb 19, 2008 | 08:08 PM
I do plan on keeping the gold/white combination wouldnt have it any other way!
455Olds
Aug 3, 2017 07:09 AM
DTomastik
Sep 24, 2012 09:12 PM
Jetstar1CA
Aug 25, 2010 12:52 PM
kruss77
Aug 21, 2009 07:35 AM
Brizio
Feb 15, 2009 07:07 PM
