knocking by transmission under the car
I have a problem I'm aost certain my drive shaft is knocking on the under side of the car just had the tranny rebuilt so I'm pretty sure that's not it I had the drive shaft balanced I went to install and still knocking any suggestions please!
Did you replace the trans mount? If so compair it with the old one to verify correct. Also did you take out the cross member? If so is it back in upside down? (If that is possible). Is it hitting the floor pan to one side or up at the top?
Hmmm, not in the diag class of some of the above respected veterans but with your brief description, it could be as simple as needles missing from a U-joint cap to a more serious issue? Stuff a Go-Pro camera or phone under there and record that baby in motion.
Like Joe ^, detailed info is a must for the crystal ***** to focus.
At this point perhaps some pictures of your under side where its hitting, U joints, your transmission mount, and transmission cross member . Without seeing what your seeing we can only guess and have contributed many suggestions. I will add one more, worn body bushings allowing the body to drop.
TennesseeDelta
March 27th, 2007 02:01 PM
