Horn button disassembly
Old Feb 14, 2025 | 02:29 PM
mattking's Avatar
Has anyone had any luck opening and re sealing a horn button like this one from my 64 cutlass? I didn’t see the rust in the background when I got it off eBay. I would like to open it and clean it up if I can but if it will tear it up I will keep looking for a better one.
thanks in advance
Old Feb 14, 2025 | 04:19 PM
Do you have 2 buttons? I'm guessin you will have to ruin the top or the bottom to get apart- so if you have 2 you could use the best pieces and make one nice one?
Old Feb 14, 2025 | 04:58 PM
mattking's Avatar
good call Greg, Actually I do.I think I have a 65 button as well.
the button from my car is all cracked to pieces. I can at least learn a process on it.
Old Feb 14, 2025 | 05:43 PM
Could be wrong. Disconnect the horn or (-) battery cable. Push down on the horn button then turn CW.
Old Feb 14, 2025 | 05:46 PM
Ooops, I said CW, I should have said CCW.
Old Feb 15, 2025 | 10:59 AM
mattking's Avatar
Well. That was wishful thinking. The outer ring is fully crimped around the backing plate. I could not come up with a non destructive way to seperate the pieces
Huero59
Dec 1, 2023 04:32 AM
Rallye469
Jun 22, 2023 04:46 PM
sjay1989
Feb 5, 2020 04:16 PM
Bee Saint Louis
Oct 28, 2017 07:45 AM
88hurstolds
Oct 30, 2014 12:15 PM
