Helppppp
Old September 11th, 2016, 08:03 AM
Ttopcutty's Avatar
Helppppp
[B][/
Engine bolted to trans in cutlass but frame mounts off ....trans bolted to trans mount
Ttopcutty is offline
Old September 11th, 2016, 08:21 AM
2blu442's Avatar
OK your last picture looks like your way too far forward. If that's what I'm seeing then you may have the motor mount on the two forward holes. For the cutlass application you need to use the middle hole and the one toward the back. Double check this and let us know. Here's a couple photos of what I'm describing. John
2blu442 is offline
Old September 11th, 2016, 10:29 AM
svnt442's Avatar
I concur.....the mounts are in the wrong holes on the block.
svnt442 is offline
Old September 11th, 2016, 03:15 PM
Ttopcutty's Avatar
Help installing my 350....desperate
Okay so I dropped my 350 rocket in and bolted it to transmission.... Bolted my mounts to motor first.... Trans mounts bolted to trans but the motor mounts don't line up with frame in my ttop 86....please help me gurus
This is prior to us bolting it together...we did get it together
The mounts are way ahead of frame by this point trans and engine fully connected
Old September 11th, 2016, 03:18 PM
Ttopcutty's Avatar
Ok I'll check it out...is that that corporate blue 79 olds because that what I have
Old September 11th, 2016, 03:19 PM
2blu442's Avatar
Two of us commented on your last post. Did you check where the motor mounts are attached to the block? John
https://classicoldsmobile.com/forums...-helppppp.html
2blu442 is offline
Old September 11th, 2016, 03:37 PM
svnt442's Avatar
All modern olds V8's (1964 - 1990) have the same mounting locations.
svnt442 is offline
Ttopcutty
June 28th, 2016 03:48 PM
Southern_Hospitality
January 19th, 2011 12:33 PM
dhartley72
August 25th, 2010 02:28 PM
Quick Reply: Helppppp
