Heater box question
Old Jun 30, 2009 | 02:29 PM
44TEETWO's Avatar
Heater box question
Is the heater box on a 68 with air different then on a non-air car. I have purchased two heater boxes and neither one will fit. One was from a 69 and the other is from a 71. Thanks in advance.
Old Jun 30, 2009 | 03:07 PM
A/C and non-A/C boxes are completely different. The non-A/C is metal, the A/C is fiberglass and much larger. They also do not bolt up the same, so it is not easy to swap one for the other.
Old Aug 29, 2009 | 02:29 PM
44TEETWO's Avatar
Thanks Joe. You left out one thing, The box with air is a lot harder to find!
Old Aug 29, 2009 | 02:47 PM
2blu442's Avatar
If you strike out up in the Willamette Valley let me know. I should have a couple. I'm pretty sure the 1968-72 A-bodies will all interchange if that helps. Have you posted a parts wanted ad yet? I believe there's 3 or 4 other members in the Portland area. John
OLDSmobility
Oct 8, 2010 05:54 AM
cutlasssupreme71
Jan 24, 2010 12:07 PM
jeffs 89 cutlass salon
Oct 22, 2007 12:46 PM
Oct 10, 2007 05:34 PM
DJMatthews
Jan 26, 2007 05:59 AM
