Headers yes or no?
Old May 7, 2012 | 06:19 AM
Doomah's Avatar
Headers yes or no?
I am going back and forth about installing headers on my 1969 cutlass s 350 rocket, so I was wondering if anyone had any pics of 69 with headers, what I am worried about is that the headers will hang to low(I read on oldspower.com that someone had this problem) I live in new york and the roads have alot of big holes and bumps. So I am thinking of changing the exhaust manifolds and putting on my 3' pipes with new mufflers. By changing the exhaust manifolds and adding new pipes will I see more power or will it not really make a diff?
I brought these headers Flowtech 31150FLT and a completer set of 3' pipes with new mufflers
As always Thanks for any help.
Old May 7, 2012 | 06:29 AM
Since your going to do your exhaust anyway, why not install them and see what they look like. Then you can make an ed-u-ma-cate'd decision! Most headers will clear obstacles on a stock height vehicle!
Old May 7, 2012 | 07:40 AM
hookem horns's Avatar
No pics handy, but I have Hedman's & 2.5" Dynomax(Thrush) H pipe kit on my '69 350 with no real ground clearance issues. Previous owner installed them along with a mini-starter to help with interfercence issues and think you have to move the brake prop valve also. Tight fit so happy he did it - I would have probably just done duals off the factory manifolds for simplicity.
Headers and 3" pipes could hurt bottom end performance on a street motor, performance gurus can better explain the need for a little backpressure. Are your current manifolds good? Might sway your decision.
Old May 7, 2012 | 07:49 AM
Doomah's Avatar
Yea manifolds I have on now are working fine just old. So I will lose performance with the 3' inch pipes?
Old May 7, 2012 | 08:31 AM
L69's Avatar
L69
On a 350 unless its built for serious racing or HP 3" pipes will def cause you to lose bottom end. I have had several 400E blocks making anywhere from 400-450 hp on various builds and I always use 2.5" pipes. The rule of thumb is 3" if your over 550hp. I would def install headers and I just used those Flowtech on my 66 and the fitment was very good. This motor is around 425hp with lots of head/bowl work, torker intake, XE274 cam, roller rockers, file fit rings and various other speed goodies and it has 2.5". Good luck if you have any more questions PM me, I will give you my number and you can call to discuss this further.
Old May 7, 2012 | 09:34 AM
Eddie Hansen's Avatar
PJ....
Just as an aside, the 350 manifolds are the same, the muffler shop maks a block off pipe that fits on the right side, the manifolds can be removed sand blasted and coated with a ceramic type coating sold by eastwood and others, I know your working on the ground and fitting a dual exhaust system that way is gonna be a P.I.A., I think the 3 inch will be too much as well, and personally I don't like Loud exhaust as it makes long drives a little harsh sounding. I also think cars that take a little while to "wind Up" meaning highway gears in the back end just sound like wanna-bes IMHO.
on the other hand a set of 2 .25-2.5's and some decent mufflers will give you that low muscle car rumble.... just sayin, it's your car...
Old May 7, 2012 | 09:40 AM
L69's Avatar
L69
Originally Posted by Eddie Hansen
PJ....
x2
Old May 7, 2012 | 01:21 PM
66luvr's Avatar
IMO, you will not feel and difference adding headers and a new exhaust system. On the street power is generally measured by how the car feels "in the seat of your pants", how it feels when sitting stopped and shoving the accelerator pedal to the floor. You will not feel a difference here with the new exhaust.
Again, IMO, the thing which will make the most dramatic difference in the "seat of the pants" feel of power is a small stall converter in your 350 turbo trans. It frees the power up, lets the engine build some rpm quicker, and your car will roast the tires from a stop as never before. I like em!!
The blue 66 has a 400 turbo with switch pitch, with a smaller converter which has been reworked for more stall. Made a huge difference, I love it.
Old May 7, 2012 | 03:35 PM
XMWZ001's Avatar
I recently installed a set of Hooker ceramic coated super comps (1 5/8) on my 69 cutlass S. I Did have to re-bend transmission cooler lines, I did use my original starter without any heating or clearance issues. I do have an X-pipe, cutouts and Flowmaster 40'S on a 2.5" system and i will tell you what.....It made a very noticable difference (to me) in sound and seat performance.I would also recommend using studs instead of Bolts( On my set the number 4 bolt hole is obstructed by the header tube and a bolt is physically impossible to get in without cutting the flange). I do unfortunatly have ground clearance issues i have to snake at an angle in and out of most driveways and all speedbumps. Could be mostly due to untouched sagging Springs.
Old May 8, 2012 | 11:21 AM
XMWZ001's Avatar
Old May 8, 2012 | 11:22 AM
XMWZ001's Avatar
Old May 8, 2012 | 11:24 AM
Doomah's Avatar
Tks for the Pics XMWZ001
Old May 8, 2012 | 11:27 AM
XMWZ001's Avatar
Well apparently they transfered upside down from photobucket? But you get the idea.
Old May 8, 2012 | 11:28 AM
XMWZ001's Avatar
Old May 8, 2012 | 11:34 AM
Doomah's Avatar
I see them right side up :P
Old May 9, 2012 | 09:38 PM
jrmandryck's Avatar
You will lose a little HP with such large exhaust pipes on a stock 350, but the sound is good
Old May 11, 2012 | 04:51 PM
XMWZ001's Avatar
It does indeed sound very very good....Sometimes a bit too loud with the resonance of the 40 series though. I have had short moments of second thoughts on the Mufflers.
Old May 11, 2012 | 05:22 PM
Dave Siltman's Avatar
If you get the right headers, clearance should not be an issue. I have Hooker Competition (ceramic coated) on two applications similiar to yours and am extremely happy with both. One is a '69 W-31, the other is a '72 442 350.
Dan Wirth
Aug 25, 2020 05:07 AM
wiseguy58
Feb 11, 2010 04:01 PM
slowolds
Jan 25, 2010 09:32 PM
gearheads78
Oct 16, 2008 08:00 AM
