Grill Replacement
Grill Replacement
What is the minimum amount of disassembly needed to remove/replace the grills in a 71/72 Cutlass?
I have an opportunity to swap grills in a car someone's selling, and would like to do it with the least intrusion possible. I know it would be easier removing the bumper but I would prefer to avoid that.
I just removed the grills from my '71 without having to take anything else off and I'm hoping that wasn't just possible due to broken tabs.
Yes, the seller has agreed to the grill swap! He has the wrong grills in his car, but they're the right ones for mine...and I have the right ones for him.
Got it done without touching the bumper or anything else. The two top tabs were already broken off though. I think I could have done it even with all tabs intact. Just need to take your time and think it through.
Once all the screws are out, the grills and gravel guard pull out enough that you should be able to slide them up then out. I don't think you can get the gravel guard out without more disassembly though. Still have to try that on my car.
I replaced my front grilles & the stone shield last fall by only loosening the front bumper & letting it hang down. By hindsight, if I was going to do it again I would remove the bumper completely. Removing old broken grilles is far easier than installing new grilles.
