Front Dash Speaker
Front Dash Speaker
I'm looking for an original style speaker for the front dash of my '71 Cutlass.
This is the single speaker set-up for the middle. Any recommendations or leads for a new or re-pop speaker would be appreciated, thanks.
This thread might help...
https://classicoldsmobile.com/forums...termarket.html
I think there is another place or two that either rebuilds them or makes repops.
I got both of mine from Electro-Tech and they fit like stock and work good .
If that's a stereo radio you will be needink two speakers.
http://www.turnswitch.com/
I also got mine from Electro-tech. Similar to the original. Sound quality is poor at best. I only put it in to keep the dash original along with the Delco AM radio. I plan on a secret audio system for the real tunes!
I just had both of my '69 factory speakers re-coned a few months ago and they look and sound great (for an old factory-style speaker). I had mine done at:
Jackson Speaker Service
3921 Pine Crest Ct
Jackson, MI 49203
I found them in Hemmings online.
Al
3921 Pine Crest Ct
Jackson, MI 49203
Al
There are two oval holes in the rear seat frame support on each side of the pump motor. The right hole is the factory position (you could go for two speakers)- facing rearward...You neeed to cut an oval hole in the boot bag, install the speaker facing rearward and there is a painted rectangular grille that covers the speaker with special screws and nuts...blue wire feeds the speaker from the fader at the radio...runs under passenger side carpet...has metal protective cover as it passes under rear seat and white plastic clip before wire passes through backrest and to speaker...try that... oh yea, when the top is down you pretty much can't hear the rear speakers
I've got an original dash speaker if anyone's interested...only thing wrong with it is the fabric cover is torn...not sure how it happened 15 years ago when I put in a newer speaker...but it works and someone could surely repair the cover.
pm me if interested in it
http://www.flickr.com/photos/robsalb...7602930020786/
Even if you put the best speakers in the world in there, they will still sound like crap, even with holes cut in the top well.
I sealed that triangle support with dynamat and improved it some, but it is not something I brag about.
The back seat makes for a great back massager at high volume...
BAse blocking caps or reducing low frequencies at the radio, amp, or xover would be recommended, as you could not hear bass anyway.
Thanks for the great ideas and pics! I can hardly wait for the radio to arrive and begin this job. I'm not really going for big sounds here, but original is important to me. Did the factory ever put speakers in the back of Cutlass convertibles?
The above WAS about rear speakers in a convert...the early sixties cars had a forward facing speaker in the centre of the rear seat....later engineers had a brain fart...and Rob, there is a grille that goes over the speakers on the roof side of the bag...uses special bolts...hollow and threaded inside and out...bolt and nut on outside thread holds speaker and screw into inside thread holds grille...
Last edited by Yellowstatue; April 30th, 2010 at 04:05 AM. Reason: Letter fell off ribbon!
nickwhite44
January 21st, 2009 06:07 AM
