Fluids for a restoration
Old Nov 8, 2012 | 06:40 PM
hurstman1972's Avatar
Talking Fluids for a restoration
Finally finished the 72 H/O and it will be going to the tuner in a week or so for cranking (1st time since '87!). Need recommendations for proper brake fluid- DOT3?, coolant, PS fluid. I cringe thinking about the crappy gas/ethanol that'll be going into that 455, but oh well.
Thanks!
Old Nov 8, 2012 | 06:58 PM
Miles71's Avatar
Dot-5 is 100% incompatible with Dot3 and Dot4. If you have Dot3 or 4 now, then you must stay with dot 3 or 4. Its ok to mix Dot 3 and 4. Never Mix Dot 5 with 3 or 4, it will turn into sludge in minutes.
As for gas, can you buy Cam-2 in your state? Its 110 octane with pure lead. Costs about $8.49 a gallon in NH. I put in a few gallons every quarter.
Old Nov 8, 2012 | 07:39 PM
DOT3 or DOT4 shouldn't matter. DOT4 has a slightly higher boiling point, and a slightly higher gel point in extreme cold as well, but you are not likely ever to reach either extreme.
As Miles said, just do NOT use DOT5 / Silicone fluid, unless you want to permanently commit to it. It feels different (spongy), and I personally don't like the feel of it.
Dextron ATF is fine for the power steering.
"Power steering fluid," as purchased at places like NAPA, would be fine, too.
I don't think either one has been shown to be better in any meaningful way.
Coolant - whatever green stuff you can get, doesn't have to be expensive or special.
Old Nov 8, 2012 | 07:42 PM
For PS fluid, just use Dexron auto trans fluid. It's also stated in your owners manual. Coolant? I always liked Prestone. You can buy it now pre-mixed or do it yourself. 50/50
What kind of oil are you using? Or did you go with roller rockers? If you stayed with flat tappets, find some oil with high zddp - like Valvoline VR1
Old Nov 9, 2012 | 07:57 AM
Fuids
Motor was completely gone thru and is set up to run the crap gas we pump these days. It has flat tappets. The crankcase is already full, as is the tranny. There's no fluid at all in the brake system, PS system, or the cooling system. I want to get it right the first time tho!
Thanks to all!
Old Nov 9, 2012 | 08:22 AM
Lady72nRob71's Avatar
Dextron tranny fluid is recommended for the PS by bot the owners manual and by PS pump/gearbox rebuilders.
Use it in your tranny, too.
I always ge tthe straight Prestone green coolant and mixed myself with distilled water. The premixed crap costs the same as the straight and the water is only a buck a gallon.
Brake fluid has been touched on already - I would use 3 or 4.
Oil? Something with higher ZDDP, as regular oil now have very little. Diesel oils have more than regular oils but not as much as they used to. Use the weight as suggested in your owners manual.
Old Nov 9, 2012 | 08:35 AM
Hairy Olds's Avatar
Shoveling Snow
Take a look at this for coolant.
http://www.google.com/url?sa=t&rct=j...1q9W9sbBRzwmMQ
Old Nov 9, 2012 | 10:00 AM
Miles71's Avatar
Did you convert your AC over to R-134a? If so, did you switch to barrier hoses?
Old Nov 9, 2012 | 10:34 AM
The entire A/C system was refurbed by Classic Air with barrier hoses and all the right bits to run on R12. Keeping it "old school"! Now all I need is a Pink Floyd 8Track!
Old Nov 9, 2012 | 10:38 AM
Visit your local thrift stores and flea markets for 8-tracks. I found some cool ones a while back at those places.
Old Nov 9, 2012 | 05:33 PM
White_Knuckles's Avatar
No expert here but I like to break in new motors on conventional oil. I run two changes with Castrol GTX and then switch 'em over to synthetic. I dump the first fill around 200-500 miles. Next change when she's logged 1000 or so.
Some may point out to use "dino" oil only. I've never experienced problems using Synth except with tired engines. Please use quality filters and not the orange can of death - Fram.
wozz
Dec 22, 2013 07:37 AM
fasteddi
Jul 10, 2011 06:16 AM
venividivici53
Oct 15, 2009 10:32 AM
wolfman98
Apr 15, 2009 06:07 PM
tarps3
Ninety-Eight
Oct 18, 2006 07:08 AM
