engine swap
Old Jan 3, 2007 | 01:53 PM
78olds's Avatar
Question engine swap
i have a 78 cutlas with a 260 olds in it id like to change moters and tranny what will bolt right up with no problems will a 350 and 350 turbo tranny work that was in a chevy? id like to find an olds moter but dont seem to have any in my local area and 350 chevy small blocks are a dime a dozen thanks for the help.
Old Jan 3, 2007 | 08:59 PM
texasred's Avatar
Tom Servo's Stunt Double
Welcome to the grand illusion. Ch#vy motor swaps require a LOT of work. Do a search on this site. I think you'll find the answers.
Be patient. You'll find an Olds motor.
C.J.
Old Jan 3, 2007 | 10:06 PM
2blu442's Avatar
Where are you? I'm in Oregon and I have several extra engines. Also.... a few years back I saw a 455 in a 1978 Cutlass. It filled the engine compartment, but it worked!
Old Jan 4, 2007 | 06:12 PM
OldsMotion's Avatar
OldsMotion
Yes a 455 will fit, but I recommend finding the stock notched valve covers if you want a little extra clearance near the AC unit.
I did a 260 to a 307 swap. Took the 307 from a Buick Riviera and got SCHOOLED on the rebuild. If memory serves I hade to change over the oil filter mount, the exhaust manifolds, a few accessory brackets, the fuel pump...and the kicker....the FLYWHEEL! I say this because I had the whole thing back together and all bolted up, jumped in it for the moment of truth and the starter never touched the flywheel.
ANYWAY I digress. Small block Olds motors are still very easy to find. Look in the local yards in big Olds and Buicks, and the 78-80 Firebirds had an Olds 403 (they are harder to find). Everything will bolt up to stock locations however you may have to reposition a sensor or two depending on what the motor comes out of.
And last of all PLEASE PLEASE I BEG OF YOU....DON'T desicrate your Olds with a Chebby motor!!!
Have Fun!
John
Old Jan 5, 2007 | 07:29 AM
78olds's Avatar
thanks for the info id really like to find an olds motor sounds like a 403 would be a nice motor what would be a good tranny to put in with a sm. block
Old Jan 5, 2007 | 07:30 AM
78olds's Avatar
im in delaware if any sm block olds in the area let me know
Old Jan 5, 2007 | 02:43 PM
OldsMotion's Avatar
OldsMotion
I have a 1972 350 shortblock, and can get some #8 heads that I would consider delivering or meeting halfway from Fayetteville NC. I'm thinking Richmond would be halfway. HOWEVER I am about to score a running 403 (I keep fingers crossed and HOPE) out of a 1978 Electra...heh heh hehe.
And a TH350 is ample behind a smallblock. Heck my dad runs a metric 200 behind a 455...but never sees over 70MPH.....
John
Old Jan 5, 2007 | 03:43 PM
78olds's Avatar
that would be great john i can be to richmond in 3.5 hrs
Old Jan 5, 2007 | 09:30 PM
OldsMotion's Avatar
OldsMotion
I can get to Richmond Raceway in about 4 hours... Check your PM's
John
805cut
May 3, 2012 08:11 PM
'69CutlassVert'
Aug 25, 2011 07:19 AM
oldsmobum
Jan 14, 2011 10:10 PM
<maxone>
Nov 28, 2008 11:57 PM
ferg87
Aug 3, 2004 08:33 AM
