Dynos?
Old May 13, 2008 | 09:36 PM
Newkid8's Avatar
Dynos?
I have a 1970 Cutlass S with a 455 engine. I am unsure of how much horsepower it has. It has been modified with an Edelbrock racing carburetor and some other things that I can't think of off the top of my head. Does any one know where I can find a Dyno in South Texas specifically the Harlingen area? Or, I would be satisfied with knowing how much hp a typical 445 would output.
Old May 14, 2008 | 05:10 AM
Oldsguy's Avatar
Past Administrator
Depending upon the year, which could determine the carburetor (4 or 2 bbl), the heads (about five different ones), and exhaust, I think the advertised hp ratings were between 280 and 365. For a 1970 model I think it was 310. Someone verify that please, working off memory.
Old May 14, 2008 | 07:38 AM
88 coupe's Avatar
Junior Member
Advertised HP was exactly that.
Beginning in about '54, HP numbers began to be related more to marketing needs, than to actual power output.
Originally Posted by Newkid8
........ I would be satisfied with knowing how much hp a typical 455 would output.
Even if one knew exactly what you have, any number would still only be a guess. Then, even if you had an accurate number, its usefulness would be in doubt.
As far as a dyno goes. Your local machine shop/engine builders should know where they are. Any race tracks, drag strips, off road courses, lakes, etc, where you can find racing engines and their owners?
Norm
