Dual exhaust question
Old Dec 29, 2021 | 09:17 AM
Black76's Avatar
Hello all,
I've got a question about dual exhausts. My '76 came with a single exhaust like most did. I would like to put dual exhausts on it. Upon looking underneath the car, I saw that the transmission shift linkages are right in line with where a left exhaust pipe would traditionally go. I know there are double hump crossmembers on the earlier cars, but I'd like to avoid replacing that if possible. Could I run the pipes closer to the outer edges of the frame? How have you guys run your pipes?
Old Dec 29, 2021 | 10:23 AM
The equalizer rod from the frame to the trans is the same part number from 1973-1977 on the A-body cars, and dual exhaust was a factory option in 73-74.
Old Dec 29, 2021 | 10:27 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Go to a good muffler shop and they should have no problem installing duals. I think it will be very difficult without the double hump crossmember.
Old Dec 29, 2021 | 01:54 PM
Black76's Avatar
I was afraid of that. I don't have a lift or even a transmission jack to hold up the trans. while I swap out crossmembers. I'm working out of my garage, so I don't have access to a lot of air tools.
Are the crossmembers bolted in or riveted in? I think on my pickups they're riveted in.
I was hoping I'd be able to run the exhaust pipes along the frame rails, but maybe that's not advised.
Old Dec 29, 2021 | 02:04 PM
All you need is a normal floor jack and a short piece of 2x4. You're not removing the trans, just lifting the back of it enough to take the weight off the crossmember. The crossmember is bolted in - it has to come out to remove the trans. And you should plan on running the pipes exactly where the factory did on the 1973-74 dual exhaust cars, which is not along the frame rails. Don't overthink this. GM did all the engineering for this almost half a century ago.
Old Dec 29, 2021 | 02:12 PM
Black76's Avatar
Thanks for the info. I will see if I can locate a double hump crossmember locally.
Old Dec 29, 2021 | 04:52 PM
herkguy's Avatar
Pm me for a guy in Iowa that may have some parts for you, I’ll give you his info. I know he has several years of different parts, he may have one for you.
eric
Old Dec 29, 2021 | 05:12 PM
If you are taking the car to a exhaust shop for a factory type dual exhaust, (which is what I would do also), why not just get a dual hump crossover and ask them to install the crossmember while they are bending/installing the dual system?
Old Dec 29, 2021 | 05:47 PM
redoldsman's Avatar
That is a good suggestion Greg. They will have it on a lift and it will be easy for them to do. It will save you a ton of frustration. It might be a good time to change the transmission mount.
Old Dec 29, 2021 | 09:40 PM
Black76's Avatar
Those are great suggestions. I think that is the route I’m going to take.
Old Dec 30, 2021 | 01:14 AM
Inline's Avatar
G-force sells dual-hump crossmember for your car, and Summit aswell. Atleast on some point the Summit crossmember was actually G-force, just cheaper. Go figure.
You need to enlargen the bolt-holes at frame a bit, but otherwise its a bolt-on deal. And its not touching shift-linkages / anything if factory-routed. That is, if you cant locate factory dual-hump crossmember, or dont want to fabricate your own.
Old Nov 28, 2024 | 06:25 AM
Richard Bauer's Avatar
Dual exhaust crossmember
You will need anew intermediate parking breaks cable because the one you now have is too short . The 74 cars use a 106 inch cable which will work well to be able to use the parking brake !
Harp 1
Nov 1, 2021 12:52 PM
R_CK_R
Feb 16, 2018 08:47 AM
djcrook73
Ninety-Eight
Dec 12, 2012 02:09 PM
ragtop71
May 4, 2011 04:25 PM
SPEEDROCKET
Dec 17, 2007 07:01 PM
