Doors won't latch
Doors won't latch
I put new door latches on my 1970 Cutass and now they will not latch. I'm pretty sure the posts are lining up but it acts like they're hitting solid metal when you try to close the door. Can the post go bad and not allow the latch to close?
my door just for comparison
1st is open
2nd is closed
3rd is post. shows wear but works.
Do the new latches match the ones you took out?
Maybe try to insert the (removed post from the body) into the latch and see if it will latch. If everything worked before you changed the latches the new latches themselves may be the problem. Good luck.
2nd is closed
I have cycled them manually and removed the post and inserted it manually to make sure it fit in the latch. As far as working before the car has been sitting for several years and the doors were stuck shut,I had to release the latches from inside the door with a hammer and a long flat bar,as a matter of fact I still do not have the passenger door open yet
Is it a convertible?
Is there any frame damage?
If you grab the door and lift, does it move? maybe the hinges are worn and the doors are sagging. Evidence of that will be flat spots on the top of the post.
no sagging doors , no frame damage, just large amounts of rust It is a Cutlass Supreme non convertible, going to give opgi a call tomorrow to see if there is any history of this with these latches before
jensenracing77
Dec 4, 2015 05:01 AM
halfmoontrail
Feb 22, 2013 12:14 PM
Limey
May 3, 2010 08:16 PM
