dist rotation
Old Oct 4, 2015 | 09:12 AM
neatolds's Avatar
dist rotation
does a oldsmobile dist rotate backward from chev?
Old Oct 4, 2015 | 09:15 AM
Yes, CCW. I prefer to call it opposite vs backwards.
Old Oct 4, 2015 | 09:56 AM
1970-W30's Avatar
Not all Oldsmobiles, the 1961 to 1963 215 V8 dist rotate clockwise.......
Old Oct 4, 2015 | 10:21 AM
Because it isn't an Olds motor, it was designed by Buick...
Old Oct 4, 2015 | 01:00 PM
1970-W30's Avatar
Doesn't matter who designed it, the guy that tries to rewire his 61-63 f85 and has checked the "search" feature for distributor rotation and is assured its CCW will be pissed because his engine won't start. That's why it needed mentioning.......
Old Oct 4, 2015 | 01:54 PM
So what about the Poncho 400 used in the 1975 full size cars? The Chebby 350 and 305 used in various Olds products starting in 1977? Sorry, one needs to specify the ENGINE manufacturing division, not the car it's installed in. All OLDSMOBILE-sourced V8s use the CCW distributor.
Old Oct 4, 2015 | 02:09 PM
1970-W30's Avatar
I know it's splitting hairs, but original poster did not ask specifically Oldsmobile engine, just Oldsmobile, I can't read his mind for all we know he has a 215 or a 400 or whatever. Now it's clarified, it wasn't with the first answer.
Old Oct 4, 2015 | 05:05 PM
jaunty75's Avatar
No, Chevy distributors rotate backwards from Olds!
Old Oct 4, 2015 | 05:15 PM
Jaunty's got this one.
... And those Chebby fuel pumps are upside down, too.
Old Oct 4, 2015 | 07:36 PM
neatolds's Avatar
it is a olds 350 in a 1980 old cutlass calais. so what your saying is that olds dist run opposite chev dist. i know chev 4 bbls won't bolt up to olds 4 bbl intakes they are just a little off.
Old Oct 4, 2015 | 07:42 PM
biggus's Avatar
HA HA, how long did it take you to figure it out? Took me two days and countless distributor removal and installs.
Old Oct 4, 2015 | 09:21 PM
... chev 4 bbls won't bolt up to olds 4 bbl intakes they are just a little off.
Who told you that?
Old Oct 5, 2015 | 06:53 AM
Originally Posted by MDchanic
Who told you that?
Well, the Chebby Qjets do have that funny angle on the fuel inlet...
(Yeah, I know the 66 Olds Qjet also has a side inlet)
Old Dec 19, 2015 | 12:46 PM
Octania's Avatar
Follow the vacuum advance unit into the dist'r then around the shaft.
That is the way the dist'r turns.
This works on any engine ever made that uses vacuum advance
Viewed from above or below or either side.
It is always true.
convertible 63
May 9, 2018 06:10 AM
stormcustoms
Oct 27, 2015 05:52 PM
crazy'boutOlds
Feb 17, 2008 12:32 PM
abody
Jan 18, 2008 07:56 PM
camaro4x4
Jul 6, 2006 11:04 AM
