Decode 64 cutlass cowl tag
Old May 1, 2019 | 06:29 AM
Jmullins's Avatar
I need a little help decoding this tag.
03C
Style 64-3237 body LA15507
Trim 968 paint R-R
ACC S-2K-G-3D
So Far I've got built March 3rd in Lansing.
Cutlass Holiday 2 Door
Alamo, Cashmere, or Desert - Beige top and bottom
Looks like the 2K-G is automatic-console
What I'm having trouble with is the 968 trim and the S and 3D accessory codes
I'm not seeing 968 as an option on any decoders.
Right now the car is black with black interior. Buckets and a console automatic. It also has power steering and I think its supposed to have A/C (has vents and controls but no compressor or condenser)
Just curious. Any help is appreciated, Thanks!
Old May 1, 2019 | 06:48 AM
lemoldsnut's Avatar
I also have nothing for the 3 D But the S is for power trunk,
also nothing for 968
Old May 1, 2019 | 07:11 AM
Jmullins's Avatar
Power trunk? Interesting. I don't have anything up front that would open the trunk that I can find. Any ideas where that's supposed to be?
Anyone know if power steering and power brakes were standard or an option in 64?
Also the dash looks original and is black so I'm thinking the black vinyl is probably correct but that code is 960 and mine is painted over but is clearly 968.
Old May 1, 2019 | 07:18 AM
lemoldsnut's Avatar
vacuum switch in the glove box.
Old May 1, 2019 | 07:21 AM
Jmullins's Avatar
Ok, THATS what that vacuum hose under the dash is for haha! The glove box is gone but there's a hose going over there I had no idea what it was for.
Thanks for that!
Old May 1, 2019 | 07:48 AM
Trim code 968 is Saddle Vinyl for the 1964 model year. The available options are shown in the SPECS booklet.
Old Aug 17, 2019 | 12:23 AM
Damikestr's Avatar
Curious about my cowl tag.
As accy, I don’t see what “A20” is, or the 0321 on mine. Also wondering what the “3” they stamped on it by “trim “means. Here’s mine
Old Aug 17, 2019 | 05:32 AM
Your car was built at Fremont, and the Fremont plant used a different cowl tag format than did the rest of the GM plants in the 1960s. RPO A20 is Custom Seat Belts. 0321 is a Fremont-unique code number that likely ties to the build sheet.
Clipperet
Mar 22, 2025 05:45 AM
harleyrules
Aug 17, 2018 01:50 PM
Oldracerjones
Feb 7, 2014 06:46 PM
starr88
May 22, 2011 04:19 PM
Clipperet
Aug 24, 2010 04:17 PM
