Chevy 350 SB boltin up to tranny
Old Sep 11, 2006 | 08:38 PM
t_visker's Avatar
I have a chance to get a rebuilt chevy 350 SB for 350 bux!!! I have the 87 cutlass supreme brougham.. nott sure what transmission.. but would this bolt up to it.. the tranny has OD.. and its an auto..
Old Sep 12, 2006 | 04:48 AM
Oldsguy's Avatar
Past Administrator
No, wrong bolt pattern on the bell housing.
Old Sep 12, 2006 | 05:45 AM
t_visker's Avatar
bell housing
couldn't I just change the bell housing??
Old Sep 12, 2006 | 07:29 AM
orange442's Avatar
Swap?
If it is a 200-4R OD it should have the dual bolt pattern and will bilt up to the Chevy engine. You will have to change frame mounts and engine mounts or it will not bolt up to the frame. You will also have to get all of the accessories and brackets with the Chevy because none of the Olds stuff will bolt up to the Chevy. If you can find a Olds 350 or 403 it would be a better route to go because it would be a direct bolt in. Might vsave you a lot of hassle and money sticking with the Olds motors.
Old Sep 12, 2006 | 07:47 AM
texasred's Avatar
Tom Servo's Stunt Double
Plus the starter is on the wrong side as is the alternator and A/C. Figure a lot of splicing and new A/C lines (if you are going to use it).
Go with the SBO.
C.J.
moys71
Feb 16, 2021 08:22 PM
TOONLOVESCHERYL
Feb 4, 2016 06:30 AM
69OLDSCUTCONV
Feb 1, 2011 06:09 AM
gscott819
Jul 28, 2009 07:02 PM
