Carburetors
What engine, what intake manifold, and do you want original replacement or performance upgrade? Also, are you subject to emissions testing where you live? If so, this will restrict your choices.
OK, that answered the first question I asked. How about the rest of them? The sooner you answer all of them, the sooner we can help you.
Is there something wrong with the original carb, or is it too far gone to rebuild?
This particular engine used the computer controlled DualJet carb, which is really the front half of the four barrel Quadrajet used on the V8. The carb has an electric solenoid that pulses tapered metering rods up and down at the command of the computer to adjust the amount of gas flowing into the engine to minimize emissions while improving economy.
Assuming the car is otherwise stock and you still have the computer system in place, the only thing that will work is a new or rebuilt exact replacement. This carb has a throttle position sensor that is required by the computer to operate properly so you must install an equivalent carb or be prepared to perform major modifications.
Have you been having difficulty finding a replacement carb? Rebuilt replacements should be readily available from all auto parts stores. Here's one example that I found from Partsamerica.com (the online branch of Advanced Auto Parts):
http://www.partsamerica.com/ProductD...ype=26&PTSet=A
The heart-stopping price is why I recommend rebuilding the original if possible - the rebuild kit is about $40.
The bigger problem is finding a mechanic who can properly set this carb up once it's bolted to the engine. There is a very specific procedure for adjustment detailed in the Factory Service Manual. This process MUST BE FOLLOWED EXACTLY. You cannot simply bolt on a rebuilt carb and expect the car to run properly. In addition, the computer is very sensitive to proper connection of the miles of vacuum hose on the engine, as well as the proper functioning of the various electronic sensors and actuators. A problem with any one of these may feel like a carb problem but it is not. It took me a month of weekends to get the electronic carb on my 86 sorted out correctly (mainly for the self-education) but now it runs great.
silverriff
February 26th, 2010 09:48 AM
