Can't Find Parts for 72
Anyone know if anyone sells the switch for my console light? Has anyone ever used a 2 terminal door jamb switch in the console?
Does anyone have a working drivers side horn? Mine quit. I took it out and rapped on it a couple times, wired direct to the battery and it worked a couple times, intermitently, but it seems shot.
Dosen't your horn have a addjustment screw on it? If so turn it and keep trying, and tapping it till it works. Probably just stuck from not being use for a while. I had one that had a wasp nest in it.
Are you refering to the screww that kind of looks like a reverse torx? It did work intermitently when I tapped on it, but I couldn't get it to continue working. The "torx" screw seems frozen.. I'll have to try some penetrating oil on it.
If you want to have your original horns rebuilt, send them to Gary. He does great work!
http://www.classiccarhorns.com/proc1.html
Post in parts wanted for the console pin switch. This should be fairly easy to locate.
davesdelta
March 6th, 2007 11:18 AM
cutlass68
December 2nd, 2006 04:18 PM
dynamic88builder
January 24th, 2006 10:52 AM
