Is this backspace difference too much for a replacement wheel?
Old Feb 9, 2012 | 12:57 PM
78ChevOlds's Avatar
Question Is this backspace difference too much for a replacement wheel?
According to this link below, the SSIII Rallye wheels for 1978-1988, had a 3.5 inch backspace for the 14 inch size.
http://www.442.com/oldsfaq/ofwhl.htm
I am looking to replace my 14 inch steel wheels with Olds SSIII Rallye 15X7 with 4.25, but is that backspace too much?
I am going to put on a 205/65/15 tire on my 78 Cutlass.
Thanks for the replies. I like to place an order with Blue Oval as soon as possible.
Old Feb 9, 2012 | 02:08 PM
This is why I like to use offset instead of backspacing. Backspacing is affected by wheel width, so you can't compare backspacing of wheels that have two different widths. Offset is the absolute dimension from the wheel mounting surface to the centerline of the wheel.
In this case, the 3.5" backspace is for a 6" wide wheel, the 4" offset for a 7" wide wheel. They are roughly equivalent as far as offset is concerned.
Old Feb 9, 2012 | 06:29 PM
78ChevOlds's Avatar
Joe,
Thanks for the quick reply. Much appreciated as this eases my mind since this car came with steel wheels and hubcaps.
Old Feb 9, 2012 | 06:50 PM
gearheads78's Avatar
car guy
I would measure closely on the rear. Depending on the tire bulge it will be close to rubbing the frame.
AZ442
Wheels and Tires
Jun 12, 2015 08:34 AM
molasses4masses
Jan 13, 2014 10:04 AM
INTRUDER
Oct 6, 2012 08:50 AM
Emreozd
Wheels and Tires
Dec 15, 2011 11:13 PM
