Back window and headliner install
Hi Mark
No, go ahead and install the back glass first. You don't want the vinyl top to be between the glass and the body metal as it can wick water through the fabric when it gets old. The stainless trim will cover where it ends. Then on the inside there is the metal tac strip that the headliner will wrap around and the vinyl trim on the inside will cover that.
John
John
Mark,
If you haven't done so already, make sure to apply paint, not just primer, in the window well area before you install the glass. It helps to seal that area from water whereas some primers can be porus and let water bleed through.
Brian
Brian
onofre442
December 1st, 2013 10:36 AM
allwood2006
November 12th, 2009 11:52 AM
