advice on positrack...
I am preparing to change the fluid in my 1969 Cutlass, which has a 12-bolt positrack rear-end.
What fluid should I use when I replace the rear diff cover with a new gasket, and how much fluid will I need?
Thanks,
NS
Thanks,
NS
The '69 Chassis Service Manual (page 4B-36), says to use special lubricant number 1050081 or equivalent for your anti-spin differential. I'd check with your local GM dealership to make sure you have the right stuff - they might unsuspectedly sell you the wrong fluid at an auto parts store. As well, if you have a type "O" differential, it should hold approximately 3 3/4 pints. If you have a type "C" differential, it should hold about 4 1/2 pints, according to the book.
Randy C.
Randy C.
There was an additive with 'whale oil' in it, that was the best, but discontinued in the mid '70's! If you could find some, it's added to regular RE 90w oil.
I've seen articles that say Red Line fluid is the best, and is synthetic, but I'm sure others will chime in.
I got my fluid from a local GM dealer (Chevrolet) at the parts counter. Just let them know you need the limited slip fluid. (pause)... Just returned from the garage and found the old bottle from the GM dealership, it says: Axle lubricant SAE 80W-90
part # is 1052271. Then below that says Gr.8.800. Been using it in my car for the last 7 years.
Actually there is much discussion elsewhere on this forum on the subject. Just a few weeks ago Brian had a few good recommendations on the subject! Do a search.
I am no expert but after looking around to i.d. mine...
Here the top pic is a Chevy type and bottom is a Olds type.
![](https://classicoldsmobile.com/forums/attachments/drivetrain-differentials/4826d1236958632-12-bolt-posi-chevy-olds-diff-covers.jpg)
The upside down "V" pattern is easy to spot compared to searching for stamps and numbers. If your car happens to be Canadian built chances are you have the C type.
Adam
Adam
