Old Jan 24, 2007 | 06:44 PM
78olds's Avatar
can anyone tell me what kind of rear came in a 1974 cutlas supreme was it posi traction ? and the gear ratio ? thank you in advance oh and will that rear bolt up to a 78 cutlas supreme thanks
Old Jan 24, 2007 | 07:39 PM
Redog's Avatar
Look at your RPO codes, should be a sticker in the trunk lid
G80 is the posi code, and the rear end gear codes will start with GU. I had GU2 in the Delta which is 2.73. I went to 3.42 which I think is GU4 or GU6
Old Jan 28, 2007 | 08:24 AM
78olds's Avatar
thanks
