86 carb problems?
86 cutlass running problems?
I have replaced the gas tank, fuel pump and rebuilt top-half of carb fixed and replaced vacum lines. I have to pump the gas pedal 2 to 3 times to start. I can drive for awhile and the car dies. Also, if I put it in neutrul before it dies it will idel fine and when I put it back in drive it dies. If some has any ideas
Hi. Sounds like two issues. First is float level, or primary pump in carb. Pull off the breather, hold open the butterfly valve, and look down into the carb as you push the throttle by hand. You should see two full streams of fuel. If not, that is your starting issue. Second, check your idle speed, and make sure you didn't miss any vacumn leaks. Hope this helps, and let us know what you find. Best of luck, Jim.
Hi there
I have the same problem.
I have the 81 Cutlass LS with the V6. Not sure about the carb though....
I had it adjusted at the workshop and it ran great. Then suddenly as I started it up again yesterday I could even get it out of the parkinglot - it just shut off. I had to drive back and forth alittle first and then it got going. Then when I got to my destination, after idling for 5 mins, it died out again....
I adjusted the carb again and it ran great. Then after some driving back and forth the idle speed went down yet again (!) and I fear the same things will happen - that it dies out.....what can all this be ?
